Best budget rear end ??
whats the best build for a rear end for a 00 ss camaro ? is it a 9 inch ? 8.5 10 bolt?? or the dana rear end ? i dont want to spend over 1000 dollars i want to have it hold at least 600 hp leaving on bottle launching 3000 without doing what my 10 bolt has done 3 times already!
who builds 8.5 corporates to fit these cars ? I see 8.5 on your list....
they are pretty tough would be a good option for those that want considerably stronger than stock but dont plan on making enough power to need a 9"/12 bolt/s60
for a grand I think you would need to be equipped to build it yourself , but its a good question cant wait to see where your thread goes
Agreed^ just dont go and invest money on your 10 bolt! You can NEVER go wrong with a 9" rear end, 9" rear ends will hold serious power and if you ever plan on going with a high HP application build you know that 9" will be there for you if you dont mind how much are you willing to pay for a rear end? 12 bolts are a bit less cheap in price, they are also good rear ends that can hold good amount of high HP
Early 10 bolts from 72 I think it was and before (60's) were 8.2 but around 73 they went to the 8.5 coporate in both bolt in axle or c clip style axle , these 8.5 10 bolts are actually really strong , damn close to a 12 bolt and way more common(easy to find cheap) many 9 & 10 second grand nationals are still running on their 8.5 coporate rears , gn's got them g body 442's/hurst olds any z28 or trans am from the mid 70's to 81 etc.... these would all be posi applications too many with decent gears such as 342 & 373.
I have a 73 ventura that has one and that was behind a straight six and glide so they put non posi 8.5 corporates in lots of stuff , I also have a 81 trans am that has one in it...
You're likely going to need to be able to learn some fabrication skills or become good friends with a fabricator. With that budget I'd be looking for a donor 8.8 out of a ranger or explorer or newer mustang with 31 spline trak loc then make it work.
LS1Tech Sponsor
http://shop.brutespeed.com/Moser-9-I...-and-Axles.htm
Check out this Moser 9 inch housing/torque arm bracket and axle package. $1,145.00 shipped. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
also is that a direct fit ?
LS1Tech Sponsor
Yes, this is a direct fit. It is the Moser housing and axle package, you would need to get a center section for it. You could get a used center section (third member) from a junkyard. If you went this way I would look for one from a Ford pick up that has a limited slip in it.
http://shop.brutespeed.com/Brute-Spe...nformation.htm Info
http://shop.brutespeed.com/Moser-12-...structions.htm Installation instructions
Bob
Bob
__________________
LS1Tech Sponsor
Thanks, I appreciate it! Bob
__________________
