how much can i lower my 98 SS?
i want to lower my 98 camaro ss. my front tires are 245s, rear are 275 on either 10 or 10.5in rim. so my question is how much can i lower it before i need to fabricate anything to prevent from any rubbing? and also, what else is needed to lower it the "right" way? ive heard i will need lower control arm relocation brackets but thats about it.. thanks
Im running 275/40R17 on all 4 on OEM SS Wheels. My tires rub only when going over a bump which causes rub on the top of the front tires. Otherwise no issues. I didnt cut my inner fenders or anything like that.
All you need are springs, but with the stock shocks the car is going to handle and ride like crap. The rear end will be pushed to the drivers side without an adjustable PHB, and your front alignment will be off as well (alignment shop can fix easily, no parts needed).
Rear LCA reloctaion brackets can help gain back some traction, but will hurt handling.
LS1Tech Premium Sponsor
After the vehicle is lowered it will push the rear end over to the driver's side of the car so using an adjustable panhard rod will allow you to center the rear end back up underneath the car and also LCA relocation brackets will correct the lower control arm angle after the car has been lowered. These are things that don't absolutely have to be done but is defintiely recommended.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
