Anyone spraying the G5X3 114LSA?
Im going to be spraying the G5X3 sometime this summer and I was wondering if anyone is spraying the G5X3 cam right now and what your expirience has been with it..
Thanks
Thanks
I'm spraying a 100 shot right now and I'm trying to decide between the G5x3 and t-rex cam. Hows the G5x3 cam? Is it any good? How much hp did you pick up on the cam alone?
Hows the x3 do off the bottle? Is there a noticeable increase in hp off the bottle? Hows the idle and driveablity? Sorry for all the questions, just trying to find the right cam.
**** i am going to spray the **** out of the G5 cam(yes the first cam in the G serices.) If some one can find me one that is good on the spray and will make better numbers than the old school G5 please let me know. Not just 10 tq and hp but like 30+ .
The G5X3 is pretty much the 'street' version of the G5X2. It will make more low end torque, be a little easier on the valvetrain, and peak sooner in the RPM range. From the specs it should be a great N20 camshaft.
To those asking questions, I have yet to install the G5X3 cam into my car, so I cant answer most of the questions being asked. Once everything is installed and in, I will post answers to your questions..
As Damian said, the X3 is larger than the X2, but not by much. I don't know the specs, but from talking to Lou, he has mentioned that it's just a tiiiny *hold your index finger and your thumb ~1/4 inch apart and squint* bit.
The X3 is available on either a 112 or a 114. While the duration/lift numbers may only be slightly different from the X2, it would seem as if the timing of the valve events has been moved around, because all of the X3 cars I have seen (a couple dozen, at least) have idled considerably smoother than the vast majority of the X2 cars I have seen (including mine).
redz- the X3 compared to the X2 is the definition of "more refined". Idle quality/drivability is better, as is top end power. I have heard mention of some loss of low end with the X3, but all of the dynos I have seen indicate that there is still plenty of power throughout the rev range.
