Lq4 turbo coldside and waste gate help
Old 11-20-2012, 09:04 PM
01snake's Avatar
Default Lq4 turbo coldside and waste gate help
Well just got a lq4 my original plan was a stock 4v and a 70mm so I bought all 3" coldside and a tial 38mm gate. Plans have changed and now have a stock lq4 6.0 with a stage 3 tick turbo cam ls6 intake head studs and gaskets.
I'm looking at 88-91mm turbos for room to grow when I build the motor
Can I just buy another 38mm gate and put one on each hot side pipe? Figure it would be cheaper then selling and buying a 60mm one
Now for the coldside how much will 3" pipe support? I don't ever plan on going higher the. 1400 or 1500 flywheel hp. Will 3" be ok or should I sell all my stuff and buy 3.5"? Car will have a big air to water if it matters?
I'm assueming a 88 or 91 is as big as I want to go on a stock 6.0 for now? I plan on running 110 and would like 700-800rwhp for now. If all goes well I will rebuild next winter
Old 11-21-2012, 11:17 AM
01snake's Avatar
Bump..
Old 11-22-2012, 11:35 AM
T76s10's Avatar
Yes, 2 38mm gates would work perfect. 3" is all you need, you dont need to go any bigger. Which turbo are you looking at? T4 or t6? A pt88 would work or you could do a borg t6 as well
Old 11-22-2012, 02:00 PM
01snake's Avatar
I would like a t6 8847 or 91mm from forced induction that's what I have my eyes on right now
Do you know how far some people have pushed 3" pipes?
Old 11-22-2012, 03:44 PM
T76s10's Avatar
3" is probably all you need. After the 1000whp mark it might be a restriction but idk. what are your future goals? Is it going to be a manual or auto? Street car a drag car? Allot of things that need to bee factored in when it comes to choosing a turbo.
Old 11-22-2012, 03:46 PM
01snake's Avatar
Full out drag car with auto, air/water ic
Will never go more then 1500hp fylwheel
Old 11-22-2012, 06:04 PM
T76s10's Avatar
Then i think the gt47 is a good choice. You have a Trans brake too? The 3" pipe will do the job
Old 11-22-2012, 06:37 PM
01snake's Avatar
Yup has brake
Quick Reply: Lq4 turbo coldside and waste gate help
