car will turnover but not start
Old 11-21-2012, 06:52 AM
mobius's Avatar
Default car will turnover but not start
Car sat for 2 weeks and i went to start it and it just turnsover. I have a fuel pressure gauge in the car and a return style system. When I turn the key fuel pressure goes to 60 then fades to zero quickly. when cranking fuel pressure does no come back and car wont start. I do not believe it is a security issue light goes out with key and i tried disabling vats in tune.I can force the fuel pump on and have pressure as well. no codes BCM or PCM. I am at a loss! car is a 2001 corvette. any ideas?
Old 11-21-2012, 05:57 PM
john j oliver's Avatar
You said your car sat for two weeks. 'Assuming it was running before the two weeks? Question was it sitting out in the rain by any chance?
Old 11-21-2012, 06:23 PM
mobius's Avatar
no garaged. and ran fine before it sat
Old 11-22-2012, 07:55 AM
Jays_SSZ28's Avatar
Have someone crank it and someone spray starting fluid in the throttle body. If it tries to run like this it's either the fuel pump or vats.
Old 11-22-2012, 09:02 AM
mobius's Avatar
I commanded the fuel pump on in hptuners and have fuel pressure doing that. Also disabled vats. Turns over doesn't try to start.
Old 11-22-2012, 09:11 AM
Jays_SSZ28's Avatar
Fuel pressure means nothing if the injectors aren't working....
Old 11-22-2012, 03:42 PM
mobius's Avatar
well yes you are right. So why arent the fuel injectors firing? ......
Old 11-22-2012, 04:29 PM
Jays_SSZ28's Avatar
How do you know they are not firing?
Old 11-22-2012, 07:12 PM
mobius's Avatar
well the pcm is obviously not allowing the car to start as it cut the fuel pump and must have cut spark as well. it would be nice if there was a code thrown so i would know where to look... so i am looking for something that will cause this with no code
Old 11-23-2012, 12:05 AM
Jays_SSZ28's Avatar
vats cuts injectors only. If you can get it to run somewhat with starting fluid then it would lead you to the fuel system or not.
Old 11-23-2012, 01:29 PM
mobius's Avatar
ok verified i have spark and i logged inj pulse while starting and i am getting pulses.
Old 11-23-2012, 10:09 PM
BuffJoeyD's Avatar
If your pressure is dropping straight to ZERO after a prime- then you either have a bad pump, a bad regulator, or a big leak in the tank. Probably one of the take lines has a split. GL
edit: Ive seen a failed set of injectors cause none of them to work. Swapped a whole rail with injectors from one car to another and fired right up. But we check all the other stuff first =)
Old 11-24-2012, 08:26 PM
1972chevelle's Avatar
+1, the regulator is cheapest to start with!
Old 11-24-2012, 08:52 PM
mobius's Avatar
pulled the pump and all good there... looking like the regulator. I forced the pump on and got pressure and still wouldnt start im thinking i may have fouled the plugs. so ill get a new set and go from there.
Old 11-25-2012, 10:45 AM
yeah if the pressure is coming up but falling straight to 0, then the regulator isnt holding.
Old 11-25-2012, 11:25 AM
mobius's Avatar
The way this setup works the pump turns on 2 sec then off to build pressure when it goes off pressure drops immediately. I'm going to try a new regulator, hopefully that is it checked everything else but the injectors
Old 12-17-2012, 10:41 AM
97camaroguy's Avatar
was this resolved?
Old 12-17-2012, 11:50 AM
mobius's Avatar
Yes it was, There is a check valve in the c5 corvette fuel system that was stuck open. I blew air through the line with the check valve in it and all good now...
Old 01-09-2013, 11:02 PM
good to hear.
Quick Reply: car will turnover but not start
