possible vaccum leak???
Was driving my 2000 camaro ss this morning and I went to turn on the a.c. and the blower is stuck on the floor vent. Tried switching it to the defroster and every other position and it just blows out the floor. Was working fine before until I tried it today. Any ideas??!?
I had a similar issue and the vacuum line to the vacuum canister was unplugged. I would definitely doubt check all your vacuum lines and maybe start spraying with carb cleaner or starter fluid to see if you have a hole somewhere. I've also heard of people having the vacuum line on the back side of the intake manifold come loose. Hard to spot.
