402 stroker and F1A estimated power
Old 11-21-2012, 11:33 AM
randall 32's Avatar
Default 402 stroker and F1A estimated power
Im going to build a 402 stroker from ls2 block. I'v been planning to stay na with some afr 230 heads. But also thought about installing a F1A kit with forged internals and I have a set of AFR 210's I could use or a set of 317 heads I have and still use stock intake and throttle body. Any idea what kind of # it would make?
Old 11-21-2012, 04:09 PM
N2OBaby's Avatar
I don't know for sure but my guess is 580-600RWHP.
Old 11-21-2012, 04:19 PM
T/A KID's Avatar
All depends on blower speed
Old 11-21-2012, 04:23 PM
randall 32's Avatar
Are the heads mentioned to small
Old 11-21-2012, 04:39 PM
T/A KID's Avatar
Not at all they will work great
Old 11-21-2012, 07:15 PM
TSterling's Avatar
I'd be awful depressed with that. My stock block ls1 and a P1 threw down 601whp.
To the OP
Properly tuned with supporting fuel 700+ isn't out of reach. Keep the blower speed in check, they don't like being maxed all the time,
Old 11-21-2012, 10:04 PM
eb02z06's Avatar
It will make a little over 900, 900 torque too if you spin faster!
Just keep the compression up and don't be afraid to give it a cam.
Old 11-21-2012, 10:38 PM
randall 32's Avatar
Thanks for the replies, what are your specs, cam , comp, pullies, boost?
Old 11-22-2012, 07:23 AM
eb02z06's Avatar
I was puillied to max out at 6K, 8" crank, 3.5" pulley. compression 10.1, cam was a 244/250 112.
Old 11-22-2012, 08:22 AM
helga203's Avatar
Love that the powers there by 6k. Nice
I know these engines can spin to 7k but with a set up like that why. Dame that cam hits that low very nice. What stage would that be of yours III, IV???? Abouts where is lift low .600's or high .500's??? Just curious
Old 11-22-2012, 08:41 AM
eb02z06's Avatar
That's from about 6 years ago buddy, cam was .600/.600.
That was one of the first cams I was trying out. It worked great but had too much overlap for a daily driver.
My new stuff is much more effecient.
Quick Reply: 402 stroker and F1A estimated power
