drag bar?
drag bar?
whats the difference between them im looking at the umi and bmr. any pros on cons on either one looks like the bmr has beefier brackets.
http://www.umiperformance.com/catalo...roducts_id=326
http://www.bmrsuspension.com/index.c...&productid=300
any info would be appreciated
LS1Tech Premium Sponsor
Here's the one you that will work for you:
http://www.bmrsuspension.com/index.c...&productid=299
BMR redesigned our drag sway bar about 1 year ago. The new one is hollow (old one was solid), so it weighs less. We increased the diameter from 1.25" to 1.375". The bar also has 2 mounting holes. One hole is 1013% stiffer than the OE sway bar and the other one is 1632%. needless to say, this bar will keep even high horsepower cars level when they launch. Another new feature is that this drag bar is a complete bolt-on as well.
15% off and $9.95 shipping this weekend, so now is the time to buy if you can.
who will be open friday after thanksgiving.I feel 1 of these drag/sway bars will be better then a 25mm sway bar .I am trying to build my car for good launches at the strip with minimal twist.
Ramey
