Racestars....can't find right backspacing.
From what I've read I need a 15" 4.75 x 5 bolt pattern with a 1.75 backspacing for the front. Well I've looked all over hell and can't find racestars in this size. The only thing summit lists is a 4.75 x 5 with a 1.25 backspacing. Does anyone know the part number for the racestars that will fit our cars? I haven't looked for the back yet but hopefully it won't be as difficult to figure out as the front. Thanks
I bought the 15x5 with 2.37 backspace and they fit flush on a 98 ws6.I called race star they do not make the 1.75 backspace. https://ls1tech.com/forums/wheels-ti...t-perfect.html Even on there website they don't have them.15x3.75 with 1.25 backspace.
so the 15 4.75 with a 1.25 backspace will work ? If the 5" wheels aren't much heavier I would probably go with those instead anyway since I'll be driving it to the track some. I also seen in your thread about the washers, are you talking about the washers on the lugs or is there a washer that slides over the hub to take out space between the wheel and the hub itself. Thanks for the help.
I have the fronts, and they are the 3.75" wide with 1.25 offset, fits on my car just fine. clears the calipers with no issues.
http://www.racestarindustries.com/catalog.html
the 5x4.75 is the bolt circle pattern.
I have the 3.75 wide fronts on mine also. They work just fine - with that said they do sit out a little further then I'd like but still work and look great. I have pics on a thread under wheels and tires asking about race stars.
Another question, would the 5" ones let me run a regular street tire instead of a regular front runner? I figure a street tire would be cheaper and have a longer life on the street.
http://www.team3wheels.com/tech_specs_tire_chart.html
You deffinately want to keep a tall tire on the front it looks better.
