Compression help for 383ci
Old 11-23-2012, 04:32 AM
venom ws7's Avatar
Question Compression help for 383ci
Hey guys,
383ci LS6.
Wiseco 3.903 -32cc pistons
Stock size head gasket.
241 Heads 66cc
How much do we need to Mill the heads to be somewhere between 9:2 - 9:8
Thanks in advance...
Sam.
Old 11-23-2012, 09:07 PM
BAD2000TA's Avatar
Stock compression on an LS1 with 241 heads is already 10.1:1. Milling the heads would increase the compression ratio. Unless your pistons are designed for low compression (ie: dished or in the hole), then you'll need lower cc heads (like the 6.0 liter truck heads at 71 cc).
Old 11-23-2012, 09:25 PM
Tainted's Avatar
Well hes got -32cc flycut pistons so that would def lower it some.
Theres a calculator for this try googling it.
Old 11-23-2012, 09:29 PM
96capricemgr's Avatar
That is a big dish. Are the piston bought already?
Old 11-23-2012, 09:52 PM
RQSGTO's Avatar
http://www.diamondracing.net/tools/
Old 11-23-2012, 10:42 PM
Super Hulk Smash
JakeFusion's Avatar
Well you're at 8.35:1 now if you're 383 specs out to a 3.903" bore, 4" stroke, and 6.125" rod.
You'd need to take off .050" to get close to 9:1 - which is an awful lot and could give you problems with manifold fitment and head flow. You could run a Cometic .040" gasket and maybe 5.3L heads and get a little more compression before milling.
Old 11-24-2012, 12:51 AM
64post's Avatar
383: 3.905" bore with 4.00 stroke crank, 10cc dish JE pistons .002" out of the hole with cometic gaskets 3.970 X .040" thick and 61cc heads is 11:1 static compression, this is my combination.
Old 11-24-2012, 09:36 AM
td1168's Avatar
You're gonna have to take alot of material off the heads to be where you want to with your current set-up. I wouldn't advise doing it. Your only option using a 32cc dish is going to be running a 5.3l head and you are still going to have to reduce the combustion chamber cc's about 5cc's which would be around .030" off the heads. Not trying to be the monday morning quarterback but you got to consider piston dish volume when buying the pistons. Your pistons are going to be a problem with getting to the desired compression ratio.
Old 11-24-2012, 01:22 PM
batboy's Avatar
To get 9 CR, you'll need to mill .045" and use .040" Cometic head gaskets. With 243 heads, you need to mill .030" with the same gaskets.
Old 11-24-2012, 01:42 PM
venom ws7's Avatar
Thanks for the all the replies guys..
A friend of mine bought the short block used I honestly told him the compression is way low for his setup (YSI) but unfortunately for the price he bought we couldnt pass the deal..
I agree and thats what I told him I also not sure it will help under 16+psi...
Thanks.
Thanks...
Like I said not my engine or setup just helping a friend...
Quick Reply: Compression help for 383ci
