new cam for my 383ci
Old 04-13-2004, 03:59 AM
FireHawk22's Avatar
Default new cam for my 383ci
Hi all.....
I whant too get anew cam and what i found is this cam in AP engineering
the cam is 248/250 the lift is around 600 is that good for my motor ,and my CR is 11.5.1 and i got the mti st2 heads manley dual springs.my pistons is lunati.do i have too make p to v clearance.
thanks,
Old 04-13-2004, 05:55 AM
StevieZ's Avatar
With the Lunati pistons, intake valve relief is .160 deep and exhaust is .120. You should be fine but it is always good to check.
Old 04-13-2004, 07:41 AM
FireHawk22's Avatar
like you think its ok i can go for this cam or i have too change it.did you make p to v clearance too your motor stevieZ when you install your cam. and what is you CR.
thanks for help stevieZ.
Old 04-13-2004, 08:13 AM
FireHawk22's Avatar
how much rwhp and rwtq stevieZ you are makeing
Old 04-13-2004, 08:51 AM
SAM98WS6's Avatar
I just put in a rapidmotorsports 242/250 .595/.595 109 cam..sounds absolutely wicked and its not even tuned or dynoed yet. Runs very nice so far.
Old 04-13-2004, 10:32 AM
DG Gordon's Avatar
How much hp are you guys making with your strokers?
