computer and harness question
im looking into buying a 99 firebird roller and was wanting to know if the computer and wiring harnesses are year specific. does it have to be a computer from a 99 or will a 2000-2002 work also? and same for the harness. thanks in advance. i have no knowledge about the lsx stuff
LS1Tech Premium Sponsor
The computer itself is the same between the 99-02s. The software between the years are different, but will still all interchange with different year model f-body harnesses.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Ok thanks. I'm going to have to get it tuned anyway because it's getting a 5.3 and some extra goodies
I haven't had luck finding a 99 specific harness so it's good to know I can use one from other years
Definitely will make it easier to find something, you can even make a 98 f-body harness work, you will just need to repin the pcm connectors...
__________________
That is defintely going to be the easiest route.
__________________
