93 Mustang LQ4 Build
Old 11-25-2012, 08:14 AM
Lawhead's Avatar
Default 93 Mustang LQ4 Build
Well I had my other thread but it was more of a questions asking thread this is going to be where I post the progress from now on
Story Time:
Well got my Firebird and realized modding my DD is not something you should really do so I figured I'd buy another car and do a Carb'd LS build the first car on the list was a 99 Camaro V6 hardtop but was told the Fox Swap is getting more and more popular with affordable swap parts. But first I searched for a motor at first I found a 07 5.3 for 200 bucks with a set of 243's so that was originally going to be the power plant. Then stumbled across another 5.3 and while I was there he told me about a 6.0 he had......So I leave there with 2 motors a 6.0 LQ4 short block with 317's ARP main studs LS1 Pistons and rods and another 5.3 for 450 bucks. So thats how it got to a 6.0 build
Specs of the Build
Stock bottom end LQ4 with ARP rod bolts
Custom Tick cam 234/242 .6XX/.6XX
Victor Jr Carb intake
850 Holly DP
243's milled .040 with BTR .660 springs
LS2 Timing set
MSD LS 6010
Motor is going to be a cam only motor so nothing to crazy on the motor side
Now for the car Picked up the car sight unseen from the Tampa area he told me all it had done and how clean it was and the car didn't disappoint list of parts the car has
AJE K-Member and A Arms
Strange Rear shocks
8 point cage
Steeda outer tie rods
Flaming river manual rack
Coil overs
3.73s
Weld Wheels
Had a 99 GT dash but was a hack job
Plan is to have the car done by April of next year and have it dialed in for the cool weather next year going to keep this updated as much as I can to keep yall up with whats going on!!
Old 11-25-2012, 08:44 AM
Jimbo1367's Avatar
Looks like a nice start. I love the bodystyyle. Just loose the hood. LOL
Old 11-25-2012, 09:23 AM
Lawhead's Avatar
Yeah cowl is a bit tall but I like the way it looks from the outside......Just not as user friendly from the inside..
Old 11-26-2012, 06:59 PM
Lawhead's Avatar
Any idea who puts metal rods in these fancy boxes?
Old 11-27-2012, 06:17 PM
Lawhead's Avatar
Got a few question for you fox guys......I'm going aluminum dash was wondering what to do about steering?? just make brackets and use a stock column or where can I find a racing steering column
Old 11-27-2012, 08:29 PM
Builtz71's Avatar
Try Holcomb motorsports,they have a lot of stuff for the fox body..
Old 11-28-2012, 07:41 AM
LSFOX's Avatar
Nothing that holds the dash up affects the steering wheel. I removed the complete metal frame from my dash and its held in by the top bolts and a pair of L-Brackets screwed into the body.
The steering is held up by a different set of brackets.
No Need for racing steering shaft unless your lightening up the car.
Old 11-28-2012, 05:32 PM
Lawhead's Avatar
Well Timing Chain,ARP Rod Bolts Oil pump and rings ordered its getting closer ;O
And Ima look for a stock dash gut it and put it in there At this point
Old 11-30-2012, 04:08 PM
Lawhead's Avatar
Heads are down at the machine shop to get milled and to get Put together with the new hardware the Bearing and lifters are on their way.........
The April "Dream" Deadline is coming up I need to get this thing done!!
Old 11-30-2012, 08:39 PM
hfthe3rd's Avatar
What kind of times / numbers do you think you will put down.
Old 11-30-2012, 08:48 PM
Lawhead's Avatar
High 10s is my goal for the car and 450 rwhp car should be under 3k with me in it
Old 12-01-2012, 10:55 AM
Lawhead's Avatar
Gave the thing a much needed bath don't mind the filthily backyard
Quick Reply: 93 Mustang LQ4 Build
