Wide-Lid Intakes from Stealth Composites +17RWHP according to manufacturer!
Old 04-13-2004, 09:52 AM
CustomPerformance's Avatar
Default Wide-Lid Intakes from Stealth Composites +17RWHP according to manufacturer!
Awesome intake, Uses largest K&N panel filter available. (from fourth gen corvette) 370% more exposed filter area than stock . Computer designed for maximum air flow. Direct bolt-on, absolutely no modifications to vehicle. Takes 10 minutes to install. Unique shape of intake creates a sound that can be easily confused for a charger. Even louder on cat-back eqiuipped cars.
ON SALE
Group purchase? Maybe - make us a list of those interested, we'll do the rest.
Old 04-13-2004, 12:43 PM
Tatoy's Avatar
How much?
Old 04-13-2004, 12:45 PM
30th TA 0219's Avatar
any shots of the set-up without the lid on? How does it fit in there? Does it replace the lower intake also? 75mm and 85mm available?
Old 04-13-2004, 12:49 PM
Tatoy's Avatar
Also will this change the inlet diameter of the intake? If so will this interfer with the BG ram air kit? I'm currently running this set..
Thanks again
Old 04-13-2004, 12:56 PM
02SSZ7D's Avatar
take the lid off and snap a pic so we can see what its all about!
Old 04-13-2004, 01:43 PM
Originally Posted by 02SSZ7D
takle the lid off and snap a pic so we can see what its all about!
Pictures coming up now, going out to our project car.
Old 04-13-2004, 02:47 PM
Here are the pictures :
and..
That's how much we love you guys, we went out in the rain!
**** This kit is also open in the bottom to allow air from the radiator area, so if you have any "tunnel-ram" kits or anything like that those will come out with the whole plastic bottom end that's there stock.
T.
Old 04-13-2004, 03:23 PM
The rubber hose and clamps expand after the intake and MAF since they have adjustable clamps, other than that the exit tube from the lid is a large oval exit which is easily about 90+MM
T.
Old 04-13-2004, 03:29 PM
02SSZ7D's Avatar
T.
could you show us what the bottom (under the filter) looks like?
Old 04-13-2004, 04:27 PM
11 Bravo's Avatar
Can you supply the K&N filter for it? Does it come with the tubing and if so, will it fit a 85mm maf?
Old 04-13-2004, 04:41 PM
Here you go, yes the rubber is quite elastic and can fit a non-stock MAF
Old 04-13-2004, 04:42 PM
Filter included, yes big MAF will fit. Tubing comes with it, everything but the throttle body and MAF is included in this kit. It's as complete as it gets.
Old 04-13-2004, 04:49 PM
Originally Posted by Tatoy
How much?
About $300.00 w. shipping depending on your location.
Old 04-13-2004, 04:52 PM
02SSZ7D's Avatar
have you guys dyno tested these thing? curious to know comparison over typical aftermarket lid!
Old 04-13-2004, 05:12 PM
11 Bravo's Avatar
With a big motor, 90mm intake and tb it sounds real good. Put me on the list.
Scalpel's Avatar
This is interesting. So is it $300 shipped w/the GP?
Also, what is the size of the opening where the tube connects, it's width and height? Thanks.
Old 04-13-2004, 08:21 PM
KYSpeedFreak's Avatar
Im interested as well...
$300 shipped to most places?
Old 04-13-2004, 08:40 PM
avezz28's Avatar
Seems awfully square and turbulant. I want to see back to back dynos with the tsp. It may work. I dont know.
Old 04-13-2004, 09:15 PM
WicketMike's Avatar
id like to see back to back also
Old 04-13-2004, 09:44 PM
I'll see if the builder's got some dyno sheets to post here. He should to suppoert his 15-17 rwhp gain. I have sold these for a while and have had no issues with people thinking it has not done what it boasts.
T.
Quick Reply: Wide-Lid Intakes from Stealth Composites +17RWHP according to manufacturer!
