1998 Camaro LSx Real Street Build Thread
Old 11-26-2012, 08:25 PM
Bigrob339's Avatar
Default 1998 Camaro LSx Real Street Build Thread
Well I guess I'll introduce myself, my name is Rob I picked up the Camaro back in April. I purchased the car with intentions of running the LSx shootout Real Street class. A little background not long ago I completed the F1A build on my Trans am that many of you followed the build thread and actually made it into GM High Tech.
Now onto the Camaro. I got it from a guy out of Indianapolis and this is how it arrived to me! Not even a roller just a shell! Once I saw it I knew Nate (my buddy helping me with the venture of building yet another car again, Thank you Nate) and I had our work cut out for us.
Got it off the trailer and the car sat while I collected some parts to get the vehicle to a roller.
Old 11-26-2012, 08:51 PM
Bigrob339's Avatar
Well once I got my rear end from Eric @ Midwest Chassis, strange S60, all of my BMR front suspension showed up and we proceed to start sanding and cleaning the underneath of the car. We decided to widen the rear tunnel for clearance of the rear end. Don't have many pictures of underneath cause it was a mess but here is a after.
Got the rear suspension and front suspension in and got the car on the ground!
All red suspension is BMR. Torque arm is Midwest Chassis. Front shocks are QA1's double adjustable with 14" spring and hard mount that Eric @ Midwest helped me get.
Old 11-26-2012, 09:24 PM
Bigrob339's Avatar
Pictures continued: Its on the ground!!
Decided to cut the core support and front wheel well to the way we wanted them.
Got my steering wheel and steering colum from Eric @ Midwest Chassis, got those mounted along with the Kirkey seat.
Had the windshield pulled out and got it over to the fabricators along with the cage from Midwest Chassis. Bill my fab guy did a amazing job putting the cage in and go my steering linkage set up.
Old 11-26-2012, 09:26 PM
GLS
GLS's Avatar
Looking great! What direction are you looking to go on the engine? Turbo or another procharger?
Old 11-26-2012, 09:39 PM
Bigrob339's Avatar
Once the cage was done we got it back to the shop and got started again. I picked up my battery box and then got my Pro style fuel cell and Ice box from the new sponsor BD racing! Got here insanely fast and quality is amazing! Nate got started welding up a aluminum tray for the battery box and ice box for the t-top well and also got the battery cut of switch mounted and installed.
That gets us up to date! Fuel cell is mount and will get pictures of that up soon. Should be ordering turbo, intercooler and hot side tubing to start the turbo kit fabrication. Thanks for looking.
Old 11-26-2012, 09:43 PM
Bigrob339's Avatar
Will be going turbo this time. Leaning towards either the Borg Warner S475 or S476. Depends what motor I decide on, not sure on that yet either. Either stock 5.3 truck motor or a forged 6.0L depends on the funds I can save lol
Old 11-26-2012, 10:01 PM
GLS
GLS's Avatar
Sounds like a fun build. I'm building something similar with a pt88 and ls1, do you ever run at Muncie drag way??
Old 11-26-2012, 10:15 PM
Bigrob339's Avatar
I will be attending Muncie often once it's all finished.
Old 11-26-2012, 10:54 PM
CROWN's Avatar
The word "stripped" was a understatement! Nice progress so far.
Old 11-26-2012, 11:16 PM
SSmoken's Avatar
you have a lot of patience lol. talk about starting from scratch. coming along nicely!
Old 11-27-2012, 10:03 AM
Bigrob339's Avatar
It already has been alot of work! I am the worst at being patient but I know it will take time and soon enough be at the track!
Old 11-27-2012, 11:48 AM
TheLS1Lover's Avatar
This will be sweet! Have you seen the Precision PT7685? Rated at like 1300HP, might be the ticket for this class.
Old 11-27-2012, 09:22 PM
navyblueSS's Avatar
Nice build!
Old 01-01-2013, 08:55 PM
Bigrob339's Avatar
Little update....saturday i took a bare 5.3 iron block I had sitting around and the crank out of my original motor out of my trans am up to a local engine builder to have them checked. If all goes well ill be ordering a set of h-beam roads and Weisco 5.3 pistons.
Starting back this week on the car after a break for the holidays should have more updates soon.
Old 01-01-2013, 10:12 PM
GrimReaper's Avatar
In on 1, can't wait to see the progress
Old 01-02-2013, 06:58 AM
SMOKNSS's Avatar
Looks pretty nice so far. Good luck with your build.
Old 01-02-2013, 11:10 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Looks great Rob! Let me know when you are ready to unload all those heavy front end parts and I will hook you up with the good stuff! Lol
Old 01-02-2013, 11:35 AM
DopeFedZ's Avatar
What gauge steel did you use for the tunnel area? I need to do something similar with mine tired of hearing it hit.
Old 01-02-2013, 11:43 AM
9sectruck's Avatar
WHAT SIZE SPRINGS on the front 14-----
Old 01-02-2013, 01:43 PM
SCott5's Avatar
Subscribed! Cant wait to follow this build! Looking great so far
Quick Reply: 1998 Camaro LSx Real Street Build Thread
