Need help with CTS-V Calipers and 2010 SS Rotors
Hey Guys,
I am putting together this package but need help finding a couple GM part numbers. I searched the forum and the internet with no luck.
This is what I have so far:
2007 4 Piston CTS-V Calipers - 89047726 & 89047727
Pin Kit - 89047711 - I assume two are required???
2010 or 5th Gen Camaro 14" rotors - Need the part number (Are these only available in blanks or are others available like a special edition or ZL1 that are slotted and drilled?)
Clips or retainers for the pads - Need the part number
Anything else other then the brake lines and pads that I will need?
Thanks guys for the help.
Hey Guys,
2010 or 5th Gen Camaro 14" rotors - Need the part number (Are these only available in blanks or are others available like a special edition or ZR1 that are slotted and drilled)
SS Rotors (for LS3,L99 cars): 92245928 - AC Delco #177-1050
No camaro rotors are drilled or slotted that I know of.
There are no clips or retainers sold separately. The pins are what hold the pads into the caliper. And according to the system the calipers include a retainer that goes over the top of the pads when you install the pins.
