newb to the lsx scene, need help on 5.3 swap
if things go right i'm buying a 99 formula roller wednesday and would like to know what i would have to do to put a 5.3 in it. im sure i would have to get ls1 brackets and accessories and oil pan, i heard something about having to drill one of the bolt holes for the alternator. the 5.3 i have is out of a 07 avalanche but not complete. i'll be doing a search to see what i can find out but just wanted to ask also. i plan on trying to stroke it to a 383 and get AI or TEA or someone to do the heads. which intake and throttle body would i need to go with also? thanks in advance
LS1Tech Premium Sponsor
If you search on 6.0 or LQ4/LQ9 swaps (several on here) you can find alot of info and possibly even some pictures on where you need to drill for the alternator bracket. I believe someone even did a write-up not too long ago, but other than that it should be a fairly straight forward swap.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
I might try to go ahead and get a 6.0 block and do a 408 since I'm starting from scratch anyway. That and find some l92's and send them to TEA or someone
Either way you decide to go, feel free to give us a call if you have any questions, we will be happy to help
__________________
