difference in LS1 vette and F-body
I apologize if this has already been posted on before, but I'm just too lazy to do a search and then read through all the threads. But my question is, what makes the LS1 in a 'vette 350 HP, and the SS is 325 HP? Is it just a different cam, intake, etc.? What's the easiest way to make a stock SS crank out the 350 ponies?
It's just GM trying to protect the Vette, a Z28 rated 45hp below the vette will dyno just about the same. Sometimes vettes will even dyno lower than the fbody due to the different rearend (I believe, someone correct me if wrong).
SN95 Director
Originally Posted by jrp
there is really no difference but on paper. they both dyno the same. thats assuming you compare the same years.
and dont be a lazy bitch, the search feature works wonders
i thought that the 350 hp for the vette was flywheel power and the numbers for the SS and Z28 is rear wheel numbers....
i saw a stock vette lay down 285-290....same as an f-body!
the guys was kind of let down..?
