Should I use nitrous
I recently bought a supercharged 04 gto and have no idea what else has been done to the motor guessing it should be around 500 hp if I were to put a fogger on it what kind of gain would I see? what damage could I do to my motor if its fairly stock? new to nitrous and just curious if it would be worth it? Thanks
Before doing nitrous i would do a couple of things.
1. Verify tune. I would get it on the dyno and make sure there is nothing wrong with your tune.
2. Verify the fuel system on the car. Check to see what fuel pump is in the car, if it has a hot wire or boost a pump. Depending on the power that it is making would determine how much nitrous you could hit the car with.
You will get cooler air charges, and more power if you have the fuel to supply the extra power. I would see your car already making 500 whp so i would want to verify that you would be able to supply fuel for nitrous. If not you could do some damage.
