2000 black on black WS6 M6
456 rwhp with 427 tq
The good:
383ci ls1
K-1 stroker crank
eagle rods
mahle forged pistons
comp cam 242/244 .610/.612 (polluter)
slp heads
high pressure high flow ported oil pump
fast 92 with 102 TB
pace setter long tubes with single 3'' exhaust to the back(no catalytic converters or muffler)
rollmaster double roller timing set
Granatelli 255lph fuel pump with racetronics wiring system
zex nitrous system
freshly rebuilt transmission
monster stage 3 clutch w/ flighwheel
tick master cylinder
subframe connectors
adj. pan hard and rear control arms
the motor, trans, and clutch have 7,000
optima yellow top battery
tuned by Ryan at RPM in Garner NC
The not so good:
needs 2 new front tires rears have some life
crack in the windshield on the passenger side
cruise control does not work
I bought the car in 2006 from a dealer in Greenville NC with a perfect paint job. after about two years i noticed the paint all the way down the right side and the front bumper was starting to fade. It has just got worse over the years, as the paint started to chip on the bumper i noticed underneath is metallic blue paint.
lastly there is a split in the bottom of the drivers seat
car has 105,000 miles
pictures will be posted shortly
The good:
383ci ls1
K-1 stroker crank
eagle rods
slp heads
fast 92 with 102 TB
zex nitrous system
subframe connectors
The not so good:
