My nitrous outlet direct port pics....
One thing I need to do is get a quick connect fitting. I want to use the stock fuel supply, but AN stuff to the intake. I've got a remote fuel for n20. Where did you p/u the
AN fitting though it looks like you are aftermarket fittings there
I like it. Have you tested yet? My 102 is there now getting worked on. I'm going with FAST rails & 4 solenoid system. Can't wait get it back.
well i tried it on the dyno today...... to run out of fuel.... on the hit you can watch the fuel pressure gauge go from 60-0 back to 60 then 0 then back to 60... like the motor is getting no fuel, the solenoid is opening and the motor is shutting off... a/f showed lean also so ill have to get more fuel to it...might as well have taken 200$ and set it on fire... would have accomplished the same thing
