Bunch of random parts
Category: Accessories
Price: $1
Location (State): CA
Item Condition: Used
LS Engine?: Fits LS Engine
Engine:
706 heads: Used, come assembled as shown, no issues, removed to put on aftermarket heads. Will ship to a head porter if you want. $150 shipped (heavy!)
799 valve springs: New take-offs, springs only, full set. I don't think these are anything special, they have faint pink stripe on the sides. $40 shipped
5.3L cam: Used, lobes are all fine, removed to put in an LS1 cam listed below. 190/191 0.466/0.457 114 LSA. $30 shipped
LS1 cam: Used, came out of an '00 LS1 so this is the more aggressive of the LS1 cams. It was a nice upgrade over the stock 5.3L cam, helped a lot in the top end. In great shape. 202/210 0.496/0.496 116 LSA. $40 shipped
Lifters: Used, pulled them out because I thought one was collapsed but it ended up being an exhaust leak $20 shipped
Pushrods: Used, all fine and straight. $15 shipped
Rocker arms: Used, all good. SOLD
Transmission:
Bunch of T56 internals: I built up a T56 earlier this year and removed lots of internals that seemed to be in good condition, such as blockers rings, 1/2 synchro, 3/4 shift fork, keys, springs, CAGS solenoid, etc. Also have some new 3/4 shift pads. Let me know what you need and make an offer.
Stock T56 shifter: Used, good condition, NOT Hurst. SOLD
SPEC throw out bearing: New, came with my SPEC 3+ clutch but ended up using the stock bearing instead. SOLD
GM pilot bearing: New, also came with the clutch but didn't need it. SOLD
T56 shim kit: New from Tick, only used a few of the shims and replaced them with what I pulled out of the T56. SOLD
Slave cylinder fittings: New fittings, both bleed and quick disconnect fittings, replaced with and -3AN lines instead. SOLD
SPEC slave shim: New, ended up not needed it. 0.115" thick. SOLD
Aluminum shift ****: Used, but like new. Anodized black with shift pattern engraved, about 2" in diameter, for M16 theads. SOLD
Hurst leather shift ****: Used, but in great shape, has the "H" on top. For M16 threads. SOLD
Poly trans mount: New, Energy Suspension 3-1158G. SOLD
Poly trans mount: New, Energy Suspension 3-1142G. SOLD
(These trans mounts are the same height, but one has "bumps" which are for preload or something while the other does not.)
Electronics:
Monster RCA cables: Used, 16' long, removed because I downgraded my stereo system. $10 shipped
Sound Quest wiring kit: New, good for 600W. Comes with 60A fuse and holder, RCA cables, power and ground cables, 8' of speaker wire, remote turn on wire, and some misc connectors. $20 shipped
Pioneer DEH-P6800MP head unit: Used, worked great until a few months ago when the display went blank. Worked fine otherwise, just couldn't see what was playing or what you were adjusting. Not sure if it's easy to fix, just thought I'd throw it up here in case someone is able to fit it before I toss it. Comes with dash kit for 99-02 full size trucks, remote, and trim piece. $40 shipped
