What springs with TSP 231/237 cam?
Sweet Cheeks
I going to be suggesting this cam to a friend and was wondering if the Comp springs that are rated up to .600 lift will be okay or not? Thanks.
LS1Tech Premium Sponsor
Definately crane or patriots! The patriot springs feature super 7 locks, titanium retainers, springs, seats & seals for $295!!
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
I have the Rev's with mine. Is there a reason you guys are saying not to use these? The Crane's were not out when I got my cam or I would have gotten those. But I'm pretty sure I have a bad lifter. I hope it has nothing to do with the Rev's.
interesting
I spoke to Comp on this many times and the response I got was that the 918's work the best when they are pushed to max capacity. Again, according to Comp the 918's can be run to a 615 lift. The down side is depending how hard you push the car, you will have to change the springs every year or two.
Comp quote "The 918's are by far our best spring on the market and will kick butt against most double springs".
Don't beat me up over this, I am just passing on the info from Comp.
I knew it
I knew someone was going to chime in on the MOST part. As I said, I am just passing along the info. I thought it was interesting that the 918's work the best at max capacity and that they could handle a 615 lift.
Sweet Cheeks
Originally Posted by SSMAN66
I suggest using the Crane duals. Scroggin Dickey is running a special on them. Check out the Sponsors and Group Purchase forum.
We have the crane's & the patriots in stock. I prefer the increased seat pressure that the Patriot's offer, but both are great springs!
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Jason
Jason
