Crossover flex joint
Old 11-28-2012, 02:53 AM
80gus's Avatar
Default Crossover flex joint
I'm wanting to but sometime of a flex/expansion joint in my turbo manifold, not because i cant line it up, I want it in the to allow expansion/ contraction. What are you lads running, what set ups do you have? the set up i have is all heavy wall so there will be no flex.
Old 11-28-2012, 03:45 AM
Moderator
denmah's Avatar
run it with no flex, i have built more than half of my kits with no flex.
Old 11-28-2012, 05:47 AM
SirNemesis's Avatar
No flex on my setup either, also heavy wall tubing. No issues here.
Old 11-28-2012, 08:54 AM
MaxxMitchell's Avatar
With that small of a kit, no flex will be fine. If you really want to run one, I use the vibrant turbo flex couplers.
Old 11-28-2012, 09:09 AM
oneoverwrx's Avatar
No flex in mine but we braced the turbo to the engine.
Old 11-28-2012, 09:12 AM
ttranssam's Avatar
Yep...built more kits then I can remember and have yet had one come back and never used one! Only the occasional brace off the motor
Old 11-28-2012, 04:12 PM
80gus's Avatar
This is good to hear, i really didn't want to run one. Thanks for your replys.
Old 11-28-2012, 07:53 PM
02anti_vnm's Avatar
What ever happened to this build? I thought it was a super sick setup, especially with all the custom built water cooled stuff.
Old 11-29-2012, 03:10 AM
80gus's Avatar
Slowly mate, there's a whole vehicle build so i got to make almost everything
Old 11-29-2012, 05:58 AM
Black98s10's Avatar
How much of a pita is it to weld ss to mild or aluminized steel? Would it work?
Old 11-29-2012, 07:27 AM
ttranssam's Avatar
it welds normal...you prolly cant tell a difference
Old 11-29-2012, 08:22 AM
Toxic-Evo's Avatar
how do you unbolt that form the motor. the heads go up at an angle out so...... you manifold can go straight up and out.
got a video of you taking it off. would love to see it??
Old 11-29-2012, 02:07 PM
80gus's Avatar
2 flanges, not in that photo, each flange is just after the collector. 3 bolt to not allow rotation of the turbo
Old 11-29-2012, 04:39 PM
blubu's Avatar
Not to hi-jack, but what if I had solid mounts and braced the turbo to the chassis with no flexjoint?
Josh
Quick Reply: Crossover flex joint
