Pointers on flushing engine and trans
Id like to ask some advice on flushing the engine and trans. My car has 86k miles. What are some of the ways you guys do this and what materials do i need to get. Also if you could add your steps you do would be awesome thanks.
LS1Tech Premium Sponsor
I would recommend just draining and replacing as well, although I would carefully check the fluids for any kind of metallic material. Is it just milage that worries you?
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Engine flushing can be done a variety of ways, from pouring in a quart of ATF and running it for a bit, all the way to hooking up to machines at the lube/rip off shops. Personally, I would just dump the oil and put in a quality synthetic and filter.
As for the transmission, well..........are we talking about an automatic? Has it been serviced at its scheduled intervals? Has the fluid/filter ever been changed? If not you might want to just leave it be or at most do a pan drop and filter change and then refill. I certainly wouldn't flush it if this unit has never been serviced before, because that can certainly kill it. If you find that incredible to believe just google the issue of AT's dying after flushing.
In summary, change your oil and filter with good quality stuff, and at most do a pan drop, filter change and refill on the AT. If you've got an MT well, do they even have oil? Lol..
Ok thanks yea i have a MT. The replys you guys gave me what i was looking for. I asked this guy i work with and he says he flushes his cars when he gets them so that got me thinkin maybe i should do that my engine has 86k miles on it i have no clue about the servicing its been thru. I know its been taken care of while ive had it, ill just stick with the regular changes then thanks
Sounds good, 86k doesnt seem to be alot of milage out these motors anyway.
__________________
