T56 Parts... internals, poly mounts, pilot and TO bearings, shim kit, more
Category: Accessories
Price: $1
Location (State): CA
Item Condition: Brand New
LS Engine?: Fits LS Engine
Stock T56 shifter: Used, good condition, NOT Hurst. SOLD
SPEC throw out bearing: New, came with my SPEC 3+ clutch but ended up using the stock bearing instead. SOLD
GM pilot bearing: New, also came with the clutch but didn't need it. SOLD
T56 shim kit: New from Tick, only used a few of the shims and replaced them with what I pulled out of the T56. $25 shipped
Slave cylinder fittings: New fittings, both bleed and quick disconnect fittings, replaced with and -3AN lines instead. SOLD
SPEC slave shim: New, ended up not needed it. 0.115" thick. SOLD
Poly trans mount: New, Energy Suspension 3-1158G. SOLD
Poly trans mount: New, Energy Suspension 3-1142G. SOLD
PM me.
