stock 5.3 twin turbo build
2700lbs 88' mustang coupe
k member coilovers{front and rear}
adj upper and lowers
10 point tied to sub frames
mini tubed
stock 5.3 iron block 862 heads{studed}
ls1 intake
ls6 oil pump
turbo 400 with rmvb and brake
3.27 gear
looking to make 600hp rwhp{want to run mid 9s}
looking to make this power as cheap as i can.
needing help with what
cam
fuel system
converter
twin turbos
can i use turbos of a diesel?
like the holeset something 35s that come on the cummins pick up?
mini tubed
ls1 intake
ls6 oil pump
3.27 gear
cam
fuel system
converter
twin turbos
