Need help finding a crank pulley removal tool
Old 12-01-2012, 04:19 AM
gmcyukon's Avatar
Default Need help finding a crank pulley removal tool
Hey guys, I ran into an issue yesterday installing my cam. I went to oriellys and got a 6" 3 jaw pulley removal tool .THAT DIDNT WORK!! Anyone kno where I can find the correct tool ?
Old 12-01-2012, 07:17 AM
Old Geezer's Avatar
That's exactly what we use..Why did it not work? Cheap Chinese junk?
Old 12-01-2012, 08:18 AM
mjs1012's Avatar
That is the correct tool...
Old 12-01-2012, 08:28 AM
The Scammer Hammer
dr_whigham's Avatar
I had the best luck with the one from Advance... Comes in a big plastic box. I struggled with 2 different ones from Autozone for a few hours before throwing in the towel and going someplace else. The one from Advance had it off in 3 minutes.
Best of luck
Old 12-01-2012, 08:39 AM
pairof69s's Avatar
the one from advance worked for me...pulley was off in literally 5 min..
Old 12-01-2012, 11:23 AM
wildcamaro's Avatar
Autozone 3 jaw puller works like a charm, although at first I was trying to pull from the outside of the pulley like a tard, the three notches on the inner hub of the crank pulley fit perfect with 3 jaw puller...just make sure you get the "big" 3 jaw and not the small one bc they have two different ones
Old 12-01-2012, 11:49 AM
DACTARI's Avatar
If the autozone puller doesn't work for you, it doesn't work for you. No amount of re-trying will get it to work. I used this on my LS2 after breaking 3 rented pullers. Came off like a knife through butter:
http://www.amazon.com/OTC-6667-Harmonic-Balancer-Puller/dp/B000P6UT2I http://www.amazon.com/OTC-6667-Harmonic-Balancer-Puller/dp/B000P6UT2I
Old 12-01-2012, 12:42 PM
wildcamaro's Avatar
Make sure you are pulling the pulley from the inside hub and not the outside!
Old 12-01-2012, 12:48 PM
badazz81z28's Avatar
I bought one from Harbor Freight. Worked like a charm.
Old 12-01-2012, 02:09 PM
gmcyukon's Avatar
I thank you guys for help .. Heading to autozone now
Old 12-01-2012, 03:18 PM
The Scammer Hammer
dr_whigham's Avatar
Autozone sucks... warning you now. I broke the small and lasrge one from there, and that's when it wasn't slipping off. Go to Advance
Old 12-01-2012, 03:32 PM
gmcyukon's Avatar
Ok cool I got another question for u guys !! I got a 5.3 lm7 and when I was taking my intake off and I broke a sensor? I'm not sure what it is but it's to the right of the Camhaft position sensor. It has a 1 or 2 prong plug-in and the top of the sensor and it's plastic ( best way I can describe it )
Old 12-01-2012, 07:34 PM
The Scammer Hammer
dr_whigham's Avatar
Pics would help... oil pressure sending unit by chance? Sticks straight up from just behind the valley cover?
Old 12-01-2012, 07:52 PM
wildcamaro's Avatar
Yea def oil pressure sensor
Old 12-01-2012, 09:09 PM
Super Hulk Smash
JakeFusion's Avatar
Are you guys buying the tool to reinstall the balancer? Does Advance/AZ/Oreillys have that too?
Old 12-01-2012, 09:18 PM
wildcamaro's Avatar
http://www.autozone.com/autozone/acc...er=231202_0_0_
There ya go...they also got a gm 1-1 1/4 oil pressure sensor socket even though you really don't need it if you have a deep well socket...
Old 12-01-2012, 09:26 PM
wildcamaro's Avatar
You may break it, but they HAVE to keep giving you new ones...
Old 12-02-2012, 01:14 AM
99Bluz28's Avatar
http://www.amazon.com/OTC-6667-Harmo.../dp/B000P6UT2I
For a stock crank pulley the one above works like a charm!
Old 12-02-2012, 02:08 AM
wilfredes's Avatar
Old 12-02-2012, 04:03 AM
gmcyukon's Avatar
Yea that's it ... Do I need that?
Quick Reply: Need help finding a crank pulley removal tool
