Best TB for nitrous.....Vendors please come in
Old 12-01-2012, 11:49 AM
QucikSilver's Avatar
Default Best TB for nitrous.....Vendors please come in
I am finishing ordering parts for my 408 nitrous motor. The only thing left I am waiting to order is the throttle body setup. I am 100% completely torn between the 6061 elbow and 102 throttle body or just putting a accufab 4150 on it. I am putting a single stage 250 hit on it. L92 heads, 11.6:1 Th400 blah blah blah. NOT A STREET CAR.
Is there anyone that has an argument that might could sway me to make this decision.
Thanks in advance.
Old 12-01-2012, 11:58 AM
thedudeZ's Avatar
I like my accufab 4150. Just be prepared to chop up the cowl and go speed density.
I had to cut the bottom of the hood as well.
Old 12-01-2012, 12:09 PM
I have a VFN 5" outlaw hood and I am going speed density either way...
Old 12-01-2012, 12:11 PM
thedudeZ's Avatar
Only reason I didn't do the elbow is I wanted the distribution of air to be as equal as possible on a single plate kit.
I wish I would have gone with a super vic.
Old 12-01-2012, 08:02 PM
10secZ28's Avatar
go 4150 or 4500 and dont look back i went with the super vic and 4500 and the setup is badass, but with the 4500 you will be cutting a lot.
Old 12-02-2012, 03:43 PM
what is the difference between the super vic and the vic jr. and also between the 4150 and the 4500. I dont want to go overkill on the setup just for the hell of it. I've done some research and I haven;t gotten a lot of info on the super vic and the 4500 setup.
Old 12-02-2012, 07:52 PM
10secZ28's Avatar
super vic is an inch and a half taller roughly but has more plenum volume than the vic jr, the 4500 will flow almost twice as much air as the 4150 but will sit way higher, mine sits at the bottom of my windshield due to needing a 4500 to.4150 spacer
Old 12-05-2012, 07:23 PM
dnkynrbk's Avatar
If you do a elbow your going to restrict air flow. If you do a accufab then you need to run a air cleaner or something for it on the street if you run it on the street. It takes one rock or one nut to ruin a motor. Ive seen it happen.
I run a 408 with a mild tune and it runs 9.30s fast 90 with a nick w. 90 mm
Old 12-05-2012, 09:18 PM
I've gone back and forth on doing a 102/102 setup or this vic jr setup. Im going to run an extreme velocity carb hat on the street with a FTP 104 and open at the track.
Quick Reply: Best TB for nitrous.....Vendors please come in
