How often do you guys change spark plugs??
Im spraying a wet 125 shot with a standalone tank. It seems like the motor gets a little sluggish after 3 or 4 bottles sprayed thru it. The question is how often do you change the spark plugs spraying all the time, It seems like they are fouling out somewhat and hurting performance.
Thanks
Thanks
Thanks
Thanks
What is your setup? There could be a few things going on, the main one of which could be your tune is off and you are either fouling or burning plugs, which would also cause a rough running engine.
The car just seemed to be running more sluggish. Ran fine but did not pull as hard. I took plugs out today and they look good. the car definitely cranked up and even sounded better with the new plugs.. Br6efs. Raced a buddy who I beat by a car a few weeks ago. Yesterday same cars race and about the same off the line but then he immediately started pulling on me. put 2 cars on me. My car just seemed like it was down on power and i have experienced this before. changed plugs and she went back to running good. Any suggestions??
Bottle pressure can drop quite a bit after a couple of full 1/4 runs, or due to a temperature drop because of the weather. Most systems want 900-950 psi to deliver optimum power. If you were, say, at 800 psi that would be a pretty good drop on hp.
