crank key?
Old 04-13-2004, 05:51 PM
batoutahell's Avatar
Default crank key?
I am putting together a stock ls1, is the crank key something you can get at any autoparts place or is it a dealer item? Anyone have a part number?
Also need the crank bolt.
thanks for any info.
Paul
Old 04-13-2004, 06:15 PM
2xLS1's Avatar
Unless you had your crank machined for one, Stock LS1s don't use a crank key. Crank bolt from GM is 12557840 or ARP makes a reusable one for about $25. The GM bolt is a TTY use once bolt.
Old 04-13-2004, 07:54 PM
In this thread
https://ls1tech.com/forums/generation-iii-internal-engine/159047-oil-galley-plugs-camshaft-end-plug.html
Big tex posted a diagram and in the first picture it shows a crankshaft sprocket key, number 27, this is what I am talking about.
Thanks
Old 04-13-2004, 08:53 PM
2xLS1's Avatar
It says that is an exploded view of a C5 LS1. I've had the pulley off on a 02 C5 when I did heads and cam on one and there was no key. I've done cam installs on every year LS1 F-body and there is definately no key on F-body cranks.
