View Poll Results: Piston Slap Poll
Have had serious occuring engine problems/damage/failure.
2
1.43%
Have ticking/knock on cold startup for 30 sec.
50
35.71%
Have loud ticking/knock continously.
18
12.86%
Have severe oil consumption.
5
3.57%
Have engine and performance# loss under 0-50,000 miles.
2
1.43%
Have engine and performance# loss under 0-25,000 miles.
3
2.14%
Have had NO engine and performance# loss over 0-75,000 miles
39
27.86%
Have had NO engine and performance# loss over 0-100,000 miles.
21
15.00%
Voters: 140. You may not vote on this poll
Piston Slap Poll
Old 04-13-2004, 06:07 PM
santino04's Avatar
Default Piston Slap Poll
Just figure Id make a piston slap poll havent seen one before. I really wanna see how many of us how affected that badly by it if not at all. Please poll your most recent or worst problem if any you are experiencing or if you have no problems at all. THANKS
santino04 is offline
Old 04-13-2004, 06:32 PM
35th SS's Avatar
just piston slap here.no problem.
35th SS is offline
Old 04-14-2004, 07:34 AM
santino04's Avatar
96 views nothing polled though. Must be no problems and only a select few lemons. TTT
Old 04-14-2004, 07:45 AM
TAQuickness's Avatar
you might consider a "check all that apply" in this poll. I bought my '00 TA used with 47k miles on it. less than 5k miles later, I find that it consumes oil at a rate of 1 quart/100 miles, knocks - slaps - ticks - burps - farts - you name it. Always sux to find out you bought a pollished turd. But, on the bright side, it forces me to build the motor up sooner than later!
TAQuickness is offline
Old 04-14-2004, 09:27 AM
ls1boogie's Avatar
No promblems with mine has 69k on it
ls1boogie is offline
Old 04-14-2004, 11:00 AM
bryan c's Avatar
My piston slap started @ about 18,000 mi. I don't hear anything immediately on start up, but after about 30 sec. or so, it starts in with the slapping. It lasts until the engine is warmed up and then goes away. I burn about 1/2 qt. of oil in 3000 mi. Has anyone had the problem solved by replacing the oil pump o-ring?
bryan c is offline
Old 04-14-2004, 11:29 AM
Scooter70's Avatar
My LS1 hasn't been fired up yet, so I can't comment on it. However, my 5.3L Silverado "piston slap" has been getting worse over the last 10k miles. It's loud, but only for the first 30 seconds when it's cold. I have 65k miles on the truck and have noticed no degredation in power or performance over the life of the truck.
Scooter70 is offline
Old 04-14-2004, 11:32 AM
Gold Phoenix's Avatar
I have some knocking on cold start, but my MPH and ET have not changed and are consistant
Gold Phoenix is offline
Old 10-26-2007, 10:14 PM
Soul TKR's Avatar
i've always had oil consumption... no piston slap though... just lifter and pushrod slap
Soul TKR is offline
Old 10-26-2007, 10:18 PM
Trunion King
bene's Avatar
I'm on almost 100K mile mark, just a tad oil consumption, initial piston slap noise at cold start and that's it.
bene is offline
Old 10-27-2007, 03:10 AM
studderin's Avatar
all .....
studderin is offline
Old 10-27-2007, 08:47 AM
oz304's Avatar
150,000+ miles no problems as yet
oz304 is offline
Old 10-27-2007, 09:10 AM
8a8mfh's Avatar
I've always had lifter noise, they were replaced under warranty at 25,000 miles. Still has the noise now at 40,500.
Noise is almost always there, cold, hot, always. Never burns a drop of oil.
8a8mfh is offline
Old 10-27-2007, 11:43 AM
john shea's Avatar
Had piston slap when I bought it at 17k miles now have 76k and still
slapping on startup for a few minutes.
john shea is offline
Old 10-27-2007, 11:49 AM
Blackhawk777's Avatar
No piston slap but there is lifter noise when it's cold.
Blackhawk777 is offline
Old 10-27-2007, 05:01 PM
Ryan02SS's Avatar
No problems or audible slap here..
Ryan02SS is offline
Old 10-27-2007, 05:48 PM
INMY01TA's Avatar
Just alittle slap at cold start up.
INMY01TA is offline
Old 10-27-2007, 05:56 PM
up2nuthingud's Avatar
i wasnt sure what to answer. i have 86k on my 98 camaro. it has no noise and doesnt burn much oil. its been 2500 since my last oil change, and its less than 1/4 qt low.
up2nuthingud is offline
Old 10-28-2007, 12:05 AM
delsold's Avatar
my car runs awesome for 70k+ on it. Only thing is some valve train noise but that started after i did my cam swap because i have some pushrod issues
delsold is offline
Old 10-28-2007, 11:52 AM
GMmexican's Avatar
Have about 62,500 miles on my 2002z28......I just get piston slap on start ups when its cold, but after it warms up it goes away. Switched to German castrol and its a little bit quiter.
I know this is normal on ls1 cars but does anyone know why this happens?
GMmexican is offline
