picked up 1999 firehawk
Old 12-03-2012, 05:50 PM
kv007's Avatar
Default picked up 1999 firehawk
couple quick questions. drivers side front headlight goes up halfway and tries to go up but cant without help. solution? drivers and passenger windows wont go down or up. passengers hardly does. radio goes on and off. help?
Old 12-03-2012, 06:30 PM
AceBoogie's Avatar
1) Headlight motors going out are common on these cars.
2) Change window motors for both sides.
3) Check the wiring for the radio for a short
Old 12-03-2012, 09:41 PM
kv007's Avatar
Thank you are headlight motors expensive?
Old 12-03-2012, 10:28 PM
PhoneniX's Avatar
also often you can simply rotate the plastic gear 180deg and it will work again or simply replace the gear with a aftermarket brass one. that is if the problem is the gear is stripped as is common, wont help if the motors shot
pricing
Old 12-04-2012, 12:09 PM
kv007's Avatar
Okay thank you so much. on to the next thing. Why in the world is it so hard to find stock cats for this. i live in cali and it came with no cats. In use to the mustang would with buying an h pipe that's stock to swap it on and your good can anyone fill me in?
Old 12-04-2012, 08:02 PM
PhoneniX's Avatar
really where have you tried looking? Your friendly neighborhood autoparts store should be able to get their hands on a reproduction piece (granted in mild steel). I never ecen considered selling used factory exhaust parts haha
I bought my car with the LT's and ORY installed already and the owner tried to skimp and not give me the stock manifolds and y pipe, i made him go to "his buddies where they did the work" the night before i arrived to be sure if i couldnt pass inspection i could atleast slap the stockers back on.
Old 12-04-2012, 08:28 PM
LopeyZ's Avatar
So who still makes a quality brass gear?
Old 12-04-2012, 08:31 PM
00Z28 ls1's Avatar
as far as the raido goes theres a thread on here somewhere about it. theres a bad solder joint in a box under the dash on the drivers side. easy fix just a pain in the *** to get out. thats my guess its a common issue and i went throught the same thing with my Trans Am
Captain Double Post
BOBS99SS's Avatar
Why dont ya just get 2 high flow cats?cats are cats
Old 12-04-2012, 10:55 PM
kv007's Avatar
i cant find a y pipe with 2 high flow cats. anywhere any links?
Old 12-04-2012, 11:25 PM
SparkyJJO's Avatar
Just get the cats welded in.
Here's a pic of the BCM circuit board with the solder joints that you most likely need to repair to fix the radio issue.
https://ls1tech.com/forums/stereo-el...-workings.html
Old 12-05-2012, 12:38 AM
kv007's Avatar
im in california though. it says you have to have specific 50 states cats instead of the 49 states ones. are they going to be able to tell the difference? is there a connection i need on one of them?
Old 12-05-2012, 08:02 AM
SparkyJJO's Avatar
Well you can get those. I'm not sure the difference.
Quick Reply: picked up 1999 firehawk
