18s off 2013 Camaro fit on 01 Camaro?
Old 12-04-2012, 09:40 AM
Camaroo1's Avatar
Default 18s off 2013 Camaro fit on 01 Camaro?
Will these rims and tires fit on my 01 Camaro? http://www.ebay.com/itm/Chevrolet-Ca...a4fd74&vxp=mtr
Old 12-04-2012, 09:45 AM
Nick V.'s Avatar
have you looked up the bolt pattern?
Old 12-04-2012, 09:59 AM
Blackpanther99's Avatar
might want to check the bolt pattern first bud, I believe 5 Gen camaros have a 5x120 bolt pattern, while the 4Gen camaros have a 5x120.65 bolt pattern. Might want to call the owner or contact the owner and ask him or simply make more research about it before buying
Old 12-04-2012, 10:42 AM
Camaroo1's Avatar
Blot pattern is the same...i'm worried about the back spacing.
Don't bother posting if you don't know. THANKS
Old 12-04-2012, 11:27 AM
Her Z's Avatar
Bolt Pattern is NOT the same. Fifth gen Camaro's have a 5X120 pattern, fourth gens with a 5X120.65, as notated above.
If you're just interested in the tires, I believe these came off of a LS or LT Camaro: P245/55/R18 which is too tall of a tire.
In case you haven't already, if you're interested in affordable wheels and tires for your vehicle, check out oewheelsllc.com. They will be able to help you with proper sizes and fittings for your vehicle.
Old 12-04-2012, 02:17 PM
Camaroo1's Avatar
After market is 4.75 and is close enough. PLEASE if ya don't know ...DON"T POST UP!
I need real user info not guesses or BS. The bolt pattern is the SAME, If ya buy wheels for your new Camaro you get 5x4.75 if ya buy wheels for yoyr old camaro ya get 5x4.75.
Someone that looks at these forums had to use these newer wheels, Please post up on the back spacing.
Old 12-04-2012, 02:26 PM
themealonwheels's Avatar
No they won't fit.
Old 12-04-2012, 02:27 PM
Camaroo1's Avatar
2000 Chevrolet Camaro 5 lug 4.75 inch or 121 mm High Positive Offset
2001 Chevrolet Camaro 5 lug 4.75 inch or 121 mm High Positive Offset
2002 Chevrolet Camaro 5 lug 4.75 inch or 121 mm High Positive Offset
2010 Chevrolet Camaro 5 lug 120 mm High Positive Offset
2011 Chevrolet Camaro 5 lug 120 mm High Positive Offset
This is off onr of the aftermarkets sites.
Old 12-04-2012, 02:29 PM
Camaroo1's Avatar
Looks to me that the tires would be WAY too tall.
Old 12-04-2012, 02:34 PM
Her Z's Avatar
Old 12-04-2012, 02:58 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
Not a good fit unfortunately
Old 12-04-2012, 03:06 PM
Lol there ya go^ they wont fit
Old 12-04-2012, 06:48 PM
badformulaLS1's Avatar
OP why come here asking for advice when you're just gona be a dick and deny information that is correct....
Old 12-04-2012, 06:55 PM
babbage1109's Avatar
5x120 will fit on a 4th gen. If they didn't then there wouldn't be a ton of guys running BMW wheels.
Old 12-04-2012, 08:26 PM
silverWS.6's Avatar
Nope they won't fit, the .65 bolt difference will cause your studs to sheer off clean.
That's what you wanna know right?
Old 12-04-2012, 08:33 PM
that is a rare occasion. i ran that spacing for 2 years without an issue
Old 12-04-2012, 08:37 PM
Captain Double Post
BOBS99SS's Avatar
Lol thread so full of fail,i have seen 5th gen wheels on 4th gens,it looks horrible but im sure it can be done,
Old 12-04-2012, 08:39 PM
exactly^ too much misinformation.
Old 12-04-2012, 09:56 PM
Mr.z/28's Avatar
Only 18s Ive seen around me are the 2010 aluminum wheels.
Old 12-04-2012, 09:59 PM
metalmilitia606's Avatar
^^^ not too shabby.
Quick Reply: 18s off 2013 Camaro fit on 01 Camaro?
