Where is the throttle blade adjusting screw on a Fast 92 TB?
Old 12-04-2012, 11:05 AM
shippershack's Avatar
Default Where is the throttle blade adjusting screw on a Fast 92 TB?
May be a stupid question, but I may try to play with the TB blade adjustment screw on a Big Mouth Fast 92mm TB to let more air in to help me start reliably when the temp drops below 60 degrees. It should be a star/torx screw...but is it on the back side of the trigger with a spring, or is it on the blade itself? Any pics? Can you access it without removing the air intake or maf or TB? Counter clockwise to open right?
Thanks, and sorry if it is a stupid question.
Old 12-04-2012, 11:16 PM
99Bluz28's Avatar
It's between the throttle cable cam and the TB opening, it has a small spring on it.
Turn the allen screw clockwise to open.
https://ls1tech.com/forums/attachmen...e-body-007.jpg
Old 12-05-2012, 10:30 AM
Thanks Man! Picture and All! Quarter turn clockwise should do it from what I've read.
Quick Reply: Where is the throttle blade adjusting screw on a Fast 92 TB?
