LS9 Headgaskets on a notched 5.3 head. Will it leak?
Well I already foolishly put my motor together with the LS9 gaskets without realizing that it had the notches in the heads.
I only read about this issue today and after going back and reviewing my tear down pics the heads did appear to be notched. Tonight I pulled the engine back out of the car and sure enough the notches are clearly visible even with the heads bolted to the block.
I also used TTY head bolts so if I change heads I will be tossing those in the garbage without having run the motor even once.
Has anyone else used these gaskets on notched heads, did they leak?
Should I just go ahead and buy another set of heads without the notches?
I think I already know the answers to my questions but I am hoping that maybe I can get away with what I have right now.
Thanks for any help!
