loose front end....need advice
hey everyone just bought a 30th anniversary camaro white with orange stripes, to tbe basic problems when I bought it on bumps or corners or going over bridges the front end would shoot all over the road feeling like a tierod.....shop said bad rod so had them change it.....so now it still does it but not as bad and I just put a umi tq arm on and its faint but still there, when in the air the front is very loose so im thinking the rack n pinion is bad,any advice please
tire wear is there one outter replaced....honestly can't check cause the rack moves with any slight of movement so id like to start with rack. then go with poly bushings but want to make sure the rack is the main issue
When you fix all that stuff mentioned above, the car will still likely feel loose. Just do a search on stock suspension and you'll find out. Stock shocks wear out really quickly. Stock springs are somewhat on the soft end and a bit high but they are decent.
Springs, shocks, swaybars are what you are looking for if you really want to turn the car into a handling machine.
LS1TECH Sponsor
Yeah, if it's ok when the roads are smooth and bumps are the issue... it's likely a shock issue.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
