exhaust question (simple)
bolting on TSP 1 3/4 long tubes with their true duel x-pipe. What do I do about emissions running no cats since im in an emissions county?
we have visual and a sniffer here in bc canada
i put on long tubes and the off road ypipe ...ended up putting a cat on the i pipe ...passed emissions here ..then just removed the cat again
Works only if it's an obd2 plugin vs the actual sniffer in the exhaust pipe. Check with a shop to check their inspection method, and go from there. Here in Massachusetts they do both, but depending on vehicle year it will either be a plug in at the obd2 connector, or plugin AND sniffer in the tailpipe on the rollers.
LS1Tech Administrator
Received 1,471 Likes
If it's an OBD scan only test, this is all you need to pass. The tuning just needs to be done in such a way that allows the DTCs to run (thus completing the readiness monitors), but not trip the MIL. Most tuners are familiar with this process.
If you have any kind of an actual sniff test, then your only options are to install cats or find a test location where friendship can be purchased.
