8.5 10 bolt questions
Well I started a thread about this in the gear&axel section but this is a more viewed part of the site. My questions are what needs to be done to run a 8.5" 10 bolt out of a 79 Camaro in a fbody? Is there a write up by chance? Also where do I find the axles I need to run 4 channel abs? And how do I go about switching to disc brakes?
Original thread:
https://ls1tech.com/forums/gears-axl...9-10-bolt.html
Also is this worth it? I have heard of guys building a 8.8 capable of holding 650hp for 6-700 bucks. Any truth in it? If so couldn't the same be done with this?
Original thread:
LS1Tech Administrator
Received 1,483 Likes
The 8.5" is significantly stronger than a 7.5". In a light weight car, they will hold up to almost as much abuse as an 8.875" 12-bolt. Having said that, I don't know what the cost or difficulty is to make one fit a 4th gen (minus the money saved since you already have the rear), and ultimately that might determine whether or not it's worth using.
Cool thanks for the reply, I'll just keep doing more searching and see what's up. With it being shorter on each side would I be able to just do a mini tub and that work or would that put my tires in to far and look dumb?
Call Moser for the rearend brackets and Kore3 for the disc brakes.
I have a 8.5 in my nova and moser said it can handle 600hp if I use 30 spline axles, weld tubes to center section, and weld ford bearings to bolt axles in. When I priced all of that it is about the same price to buy a complete 12 bolt. If your making big power I would go with a 12. If your under that and have the 8.5 already, go with it. My .02
thanks, yea idk what im going to do now. I finally talked my wife into letting me go all out as fast as possible with the car. So I think ill be going with a mwc 9" my plan is single digits so that rear wont stand up lol.
Why did they stick 10 bolt 7.5 in these rides...
Profit margin...
It's plenty strong enough to out last the 3/36 under stock power on stock tires. No need for anything stronger. The ones that do break under stock power under warranty will be either voided or honored. Either way, it's still less money out of GM's pocket then putting a stronger rear in from the start.
I am afraid I will spend 2k building my 8.5 and possibly grenade it. I am thinking 12 bolt for about same price and peace of mind.
If your worried about trashing an 8.5, an 8.875 is not going to give you much more wiggle room. Go straight to the 9 inch and don't look back. It's significantly stronger than a 12 bolt and will hold up much better to hard launches and will run you about the same maybe less than a 12 bolt.
If you're on the boarder of breaking an 8.5, then the 8.875 will only be marginally better, as there isn't a world of difference in strength between the two.
Prior to the 8.5" being introduced, the factory options for small/mid-sized cars were an 8.2" 10 bolt for lower end engines, or the 8.875" 12 bolt for performance applications. Then, in or around 1972 the 8.5" 10 bolt appeared as the standardized middle ground compromise between the slightly stronger 12 bolts and the weaker 8.2" 10 bolts that had been offered previously. Then by the mid-'70s, the 7.5" was introduced for use in basic/non-performance applications, and the 8.5 was the heavy duty/performance rear.
The 8.5" continued in full-sized cars and small truck applications, but did not find it's way back to F-bodies after the 2nd gen years.
Even the 12 bolt is not bullet proof. A few hard launches on a 12 bolt, and there is a good chance the pinion bearing is going to start singing on you and eventually take the gears
I agree.
Nice Info as usual man!... Thx for making me a lil smarter and can now go around talking about it like i know my stuff.
Its a shame the F-bodies dont have a stronger rear stock, its truely an achilles tendon.
^^ I agree with it all lol. I have learned alot on this site and I to agree on the weak rear. You would have thought by the late 90's they would have realized that the fbody was going to be modded and built. But then again I understand keeping cost low so more people will buy them they make more money and still get to sell you a 12 bolt later haha.
