Thunder Racing Trex Cam Idea
Old 12-08-2012, 02:20 AM
Sinister_Z28's Avatar
Default Thunder Racing Trex Cam Idea
Ok so i have been wanting to cam my mostly stock 1998 Z28 Camaro M6 since i got it. I have also been wanting 4.10 rear gears. Now i know big *** cams arent all that popular here on LS1 Tech from what i have read but please humor me. So the plan is if i get that cam or one thats similar and base my supporting mods around it what kind of power will i be looking at. Also what kind of power will i make just on that cam. I recently had my car dynoed and it put down 301hp at the rear wheels and 306a lbs-tq. So i would like to know your guys opinions on this setup. And yes i know i will lose some driveability.
Old 12-08-2012, 02:31 AM
2000PewterT/A's Avatar
What supporting mods, there are many variables to change the hp/tq output. You will have to be more specific on what other parts you want to use, not try to be a a**hole just want to give you the most accurate estimate.
Old 12-08-2012, 02:54 AM
The plan for supporting mods would be 1 7/8" long tubes a fast intake and tb either 92 or 102mm and probably send my stock heads to AI for some porting. As of now i only have a Borla cat back. So what kind of power would it make cam only with a good tune?
Old 12-08-2012, 03:24 AM
35th SS's Avatar
360 give or take depending on the tune.
Old 12-08-2012, 03:26 AM
Thats the cam only number?
Old 12-08-2012, 04:06 AM
bww3588's Avatar
If your going to send any heads to be ported, start with something better. Pick up a set of 5.3 heads and send them out. The larger cams like you are looking at love compression. To get the compression they like without ptv issues, you'll need the small chamber of The 5.3 head.
With the ls1 intake and only a cat back, that's about right. You may break 380 but that ls1 intake will not breathe up top where the t Rex makes all it's power.
The problem is, the t Rex won't start making power until close to 4k, and your intake and heads will stall out around 5500. So you really only have 1500 rpms worth of good power
Old 12-08-2012, 06:46 AM
sreve's Avatar
That Trex has a very narrow power band that won't be that much fun on the street
and will flat out suck w\o supporting mods and gears. 4:10s on a M6 10 bolt sounds risky. Thunder is recommending 4:30s or lower and their avertising car is running 4:56s
Old 12-08-2012, 09:19 AM
I greatly appreciate everyones feed bad what do yall think about the Trak cam from thunder racing. I believe its around 234/236
Old 12-08-2012, 09:37 AM
studderin's Avatar
really?
Old 12-08-2012, 10:00 AM
bww3588's Avatar
Yea, really...
Old 12-08-2012, 10:24 AM
So what do youbguys know about the Thunder Racing TraK cam its much smaller
Old 12-08-2012, 10:30 AM
sreve's Avatar
2400 is better than 3500rpm but.........
My 2 cents would be to get the rpm it comes in at 2000rpm or less
99-TR-TORQ-L2 Thunder Racing Custom Camshaft
"TR TRuTorq" Level 2 - 223/230 .609/.604 115 LSA 1800-6500 RPM Power Band. Excellent mid-range & high RPM power. Good bottom end and mid-range torque. Requires computer tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
LS6 intake,LT Headers, ORY,Springs, Hardened push rods. Comp trunion upgrade, Timing chain , Oil pump
Old 12-08-2012, 12:14 PM
Decadence75's Avatar
I would also suggest looking at someone other than TR to buy from as there have been many complaints and horror stories about purchasing from them recently.
Old 12-08-2012, 02:09 PM
Super Hulk Smash
JakeFusion's Avatar
Ed Curtis@FTI, Geoff@EPS, Martin@Tick, or Phil@AI would get my vote. Go to one of them for a custom cam. Ed, Geoff, and Phil all have their own proprietary lobes, and Martin can get you about anything.
Old 12-08-2012, 02:33 PM
M.BOZZ's Avatar
I agree with SREVE, run something that power band starts around 1,800 to 2,000. I run a 248 260 -615 to 636, power range from 3,600 to 7,100 in a lq4 with supported mods. I think number 2 build will be smaller cam and have good street manners
Old 12-08-2012, 02:34 PM
Fry_'s Avatar
Sending you heads to AI sound's like a solid plan, and if you do I'd get a cam to mach the heads from them also. There's also no reason to use 5.3 heads to gain compression just get there 219HCR package and you'll have 11:1CR with stock GM head gaskets and you wont loose any P2V clearance. If you've got the cash just get everything from them.
AI 219HCR heads
AI cam kit
AI ported Fast 102mm intake
Throw in all of the necessary supporting mod and you'll have a solid 440-470hp setup without having to put up with a big donkey dick cam or spending $2000 on aftermarket casting heads. Heck 440hp doesn't sound out of the question with just a LS6 intake instead of a Fast102.
Old 12-08-2012, 03:06 PM
35th SS's Avatar
Trex cam on stock ported heads on my blk.m6 its a dog down low but who stays on the low rpm anyway.pulls hard all the way to 7200 rev limeter set.running 4.57 gears on a 9in. rear.
you might have a hard time getting a cam from them TR racing.bad rep lately.good luck.
Old 12-08-2012, 03:10 PM
So would u guys recomend a custom grind from TSP
Old 12-08-2012, 03:36 PM
Nemesis350's Avatar
Just so you know, most of the opinions you'll find here on the Trex cam are unsubstantiated; meaning most of those people have never owned a car with it, and are only regurgitating other peoples misleading ideas and thoughts.
You should look up opinions and numbers posted from people that ACTUALLY run one, or at least have before. I've gone 11.7 @117 on 1.7 60ft, dynoed 405 rwhp in mid summer heat, and that's a cam only stock 853 head with a few bolt ons (LT, UDP,LS6 intake) and 4.10s out back at 3800lbs. It's VERY streetable, and a blast to run! Is it the best cam out there? No, power band is a little narrow, but it's all about knowing you car.
Aside from that, you'll need to know where YOU want your powerband to be, and in any case, a custom grind cam will almost always be better suited than an "off the shelf" grind.
Old 12-08-2012, 08:42 PM
Thank u so much for all your input now can someone explane to me lobe separation angle and what id does.
Quick Reply: Thunder Racing Trex Cam Idea
