8.8 28 spline axle
Old 12-08-2012, 01:56 PM
squirlNUTZ's Avatar
Default 8.8 28 spline axle
So, I have a 28 spline 3:73 geared 8.8. But the fbody axle is to small of diameter to fit the 8.8 spider. Anyone run into this before? I thought the axle from an fbody would fit a 28 spline 8.8 carrier.
I have never put one of these rears together with factory axle so this is a first. My friend had me put a conversion together, but was wanting to keep the cost down until after school. Any help is much appreciated.
Old 12-08-2012, 06:23 PM
squirlNUTZ's Avatar
The tag on the 8.8 was wrong! I removed the side and spider gears from the carrier and counted the teeth. 31.
So, now I'm wandering if I can simply change the side and spider gear to 28 spline gears. Any one know? Or where to look to find out
Thanks
Old 12-08-2012, 07:34 PM
hiltsy855's Avatar
I don't recall where but I read you can't just change the spider gears between 31 & 28 carriers.
Old 12-08-2012, 08:24 PM
squirlNUTZ's Avatar
Damn. That's not cool. Monday Ill have to find out for sure. This sucks, because I put new bearings on the carrier. I have a new 31 spline carrier set up I could have used.
Thanks for the reply Hiltsy
Old 12-09-2012, 09:58 AM
hiltsy855's Avatar
https://ls1tech.com/forums/gears-axl...l#post13329263
https://ls1tech.com/forums/gears-axl...ord-8-8-a.html
Old 12-09-2012, 04:49 PM
moeZ28's Avatar
I've got a 28 spline 8.8 rear out of an 03 mustang...id be willing to trade you diffs...I am gonna go 31 spline. Which diff do you have?
Old 12-09-2012, 05:46 PM
squirlNUTZ's Avatar
Trac lok from an explorer. I just put New koyo bearings on the carrier and pinion.
Where you located?
Old 12-10-2012, 08:11 AM
reinhardt02's Avatar
I thought of using my stock axles with an 8.8 swap, then I read the axles are not quite the same in the c clip area. I forget the exact difference, but I remember reading that the c clip doesn't engage quite right. I plan on ordering custom axles from Moser when I get to that point and would suggest you do the same. Why put this much effort into it and then cheap out on $400 for axles?
Old 12-10-2012, 08:24 AM
squirlNUTZ's Avatar
Cheep out? That much effort?
I built the rear over the weekend for a friend. The rear in his car ( only car) is almost done. Building the housing is easy. I tried to save him a few bucks by using a 28 spline rear, only the tag on the Rear was not correct. Just attempting to keep it simple until after winter ( Christmas )
Old 12-10-2012, 10:32 AM
moeZ28's Avatar
I'm in Ashland, KY...where are you? Mine should be a 28 spline trac lock...I hqvent pulled it apart yet...just gathering parts right now but if I can help you on this it helps me too!
Old 12-14-2012, 11:09 PM
mel88643's Avatar
sent pm
Quick Reply: 8.8 28 spline axle
