Exactly, don't use a jaw puller. Use the bolts that hold on the procharger pulley to the hub, and bolt on that puller, then screw in the center bolt and the hub should come off nicely.
Where i have the blower pulley bolts started, is that where the bolts for the puller would go? Or do i have to remove the balance pulley by removing the torx bit bolts?
