MS1 and Micro2 tune, downloads.
Old 12-09-2012, 08:56 AM
Moderator
denmah's Avatar
Default MS1 and Micro2 tune, downloads.
By popular demand!
I uploaded 2 base tunes for people to download.
http://sloppymechanics.com/tunes/MS1extra_turbo53.zip
this is the turbo 5.3 notchback that runs 9s.
5.3, ls9 cam, ls6 intake, S475 turbo, 80lb injectors. water/meth injection. 110-112 racegas.
http://sloppymechanics.com/tunes/Fai...Micro2_E85.zip
Latest Fairmont Microsquirt 2 V3 tune running fuel and spark reading off the stock crank trigger.
2003 block, 08 pistons and rods, 243/799 heads, ls1 intake, 80lb siemens deka injectors, 80mm turbo. E85 fuel, methanol injection.
note, these are the whole project files zipped, so you just unzip them and drop the folder it creates into your
Documents/tunerstudioprojects/ folder and then when you open tuner studio, you can hit "open project" and select one of these and it will load the dash, tune and other project settings automatically.
http://sloppymechanics.com/tunes/MSD6010-2bar12deg.zip
6010 map for a 2 bar map sensor, and 12deg in boost, about 24 deg at 0boost/vac and 35-40 at cruise and decel.
works great, might wanna lower the total timing to like 8 deg for your own tuning till you know whats safe.
Old 12-09-2012, 09:46 AM
quik67's Avatar
Cool!
Thanks for posting!
I was curious if I was even in the ballpark with my AFR target table, looks pretty close.
Care to share your timing map from your MSD?
Old 12-09-2012, 10:07 AM
Moderator
denmah's Avatar
yeah i can put that up for download also
Old 12-09-2012, 02:26 PM
redss82's Avatar
Nice thanks Matt probably hear from me later in the week I want the turbo
Old 12-10-2012, 04:06 PM
Moderator
denmah's Avatar
added in the 6010 tune download
Old 12-10-2012, 05:05 PM
jleews6's Avatar
Good stuff. Deman is helping allot of people out.
Old 12-12-2012, 12:05 PM
Moderator
denmah's Avatar
i like seeing junk on the road instead of jackstands, whatever i can do guys!
Quick Reply: MS1 and Micro2 tune, downloads.
