102mm plate kit with stock LS3 rail
I had this setup on my car. I am still using a stock fuel pump and it would not hold preasure so I decided to go with a stand alone fuel system. It just seemed the easiest way to do things. It gives you more options in tuning also. You can adjust fuel preasure for just the nitrous and you can run race in the stand alone so you dont lose as much timing on the bottle.
