Snapped oil dip stick !!
Help me out here guys I did an LQ9 swap into my 99' T/A I used my LS1 oil pan but I used the longer truck dip stick (not the tube just the dip stick) and it snapped in the pan .will this cause problems over time can I take the oil pan out with out dropping the cross member ? This sucks am new to these cars and am dying to drive it !!!
Yea that sucks. I don't advise leaving it in there. Cant take the pan out without dropping the kmember that I know of. I wonder if you started it and ranit just for a kinut and see if the drain plug will stick to it since its magnetic. Good luck man
Wow, shitty situation. It's possible to take the oil pan off without completely dropping the k member. See here: https://ls1tech.com/forums/generatio...-write-up.html
