LS1 barely runs, unusual circumstances. Need serious wisdom here. Where do I start?
I sold my 99Z M6 about a year ago. I loved this car, I almost cried when I saw it like this. It got destroyed by the new owner... I bought it back for a $1000. I sold the car originally with these bolt ons...
Ported FAST Intake 90mm, FAST TB 92mm, new plugs and wires, SLP lid, Pacesetter LT's no cats, TSP True Dual w/ Mufflex race mufflers, new TPS, emission delete, new o2 sensors and extensions, new fuel filter. 98,000 miles. STOCK TUNE!!! I repeat no tune... The car ran fine though, needed a tune obviously, but I went FRM, and sold it. Never had a problem like this when I had it.
Okay, well now that I have it back... It will not run right. I drove it 200 miles like this so hopefully that's a good sign. Here's what it's doing... As soon as I turn the key it revs to about 2500rpm. After 1 second (literally) with no driver input, the engine loses all power and shuts off. Like the ignition/fuel just turned off, and dies. However, I can keep it running with a little foot feed action. It misses terribly when I'm keeping it running like this though. It misses A LOT... The rpm's jump around too while I keep it going, it might stay at 1800rpm for 2 seconds then die, or rev to 4000rpm, then die. Without me touching the gas, its dies instantly. With a little courage I drove it like this. However, above about 2000rpm with a load, the car "runs" decent. Some sputter around 2000rpm, but no missing. WOT, it runs decent too, pulls okay still. Confusing already for me... While driving fine on the interstate, if at any time I push the clutch in, or put in neutral without hitting the gas, it will die, immediately. So while driving 60mph in 5th gear, running decently with cruise, push in the clutch or put it in neutral, the car dies withing 2 seconds, literally. Its ran like this for about a month he said. One day he just got in it and it started doing this. He said it sounded like a cammed idle for two days, then this, no idle ****. Good news, no knocking, and not much smoke that I can see really. It always does this, never changes. Not when it's warm out, cold out, warmed up car, cold start etc...
So after digging a little... The o2 extensions are shredded. Which shouldn't make it die immediately. I unpluggged the MAF and it idles at about 3000rpm, with no missing. Cleaned the MAF, no help. Unplugged all the sensors that didn't change anything. Tried to check for vacuum leaks, but it wont idle, and it's very, very loud. I don't see any fuel leaks. Getting a fuel pressure gauge tomorrow, let you know what that is. I can hear the fuel pump prime.
I don't know where to start. It still has no tune, and the o2 sensors are not hooked up/ working. The MAF is stock. Fuel Pump is stock, 100,000 miles now. I don't understand why it will run WOT, but not even idle for 3 seconds. I don't know what to look for for codes, cause its going to throw a bunch already like this.
Please, someone help me. I sold this car after a bad breakup, regretted it for a year. Now I got over the b**** and bought it back. I can't not love this car. Any wisdom will help.
I took the IAC off and cleaned it. Started it with it unplugged. No change, still could be bad though. I replaced the TPS with a new one, the wires seemed good, no change.
Alright guys little update. Waiting for the o2 sensors to come in a friend stopped by a scanner. O2 sensors was one code, egr another, and MAP sensor was the other code. We also noticed that timing was jumping from 14 to 39 degrees while I was running it. Also had a misfire on cylinder 5. Friend drives 02SS, so I was able to eliminate MAF. IAC was dirty, still moved. Removed it, plugged it, unplugged it, ran the same every time. Backfires and smokes now, smell really rich.
The timing degrees seemed a bit extreme. Every time I blipped throttle to keep the car running it spiked over 35 degrees but yet fell to 14 degrees at points. Crank sensor..?
No clue on how a car acts with a bad map sensor...
OK, I'm gonna sound pretty amateur right now. I'm pretty sure I pulled the MAP Sensor in about 25 seconds, I'm skinny lol... It only has 1 wiring harness and nowhere for vacuum lines to plug in right? Just pulls out of the intake and has little orange seals on the nipple where it pushes in? If that was it, which I'm 99.9% sure it was, it seemed a little too easy. It might not have been sealing great... Hopefully the new one I'm getting is a little tighter in my intake. Also it didn't feel like any vacuum lines were unplugged. I really hope they're not cause I do not wanna pull that intake off after all the injector sealing problems I had. Have you guys heard any problem with FAST Intakes fitting like poop, or leaking air? Mine has been ported...
I already have the IAC out of the TB. (See above) I'm not that bad bro, I've had the motor out of this car 3 times lol. The IAC doesnt have orange seals on the nipple lol.
Lol. Just making sure. Over looked the IAC part. You said the o2 extension was shredded. How does the rest of the harness look? Today I found mine got brittle and fell apart by being to close to the header. Wires were shorting out.
Also did you get a chance to check your fuel pressure?
I would definitely hook up the o2 just to be sure.
As far as fuel pressure. I once had a missing o-ring on my fuel pressure regulator. Caused the car not to even idle. But it would start. Pressure never got above 20.
