turbo 350
Old 12-11-2012, 01:52 PM
carbed86fox's Avatar
Default turbo 350
i have a rebuilt turbo 350 nothing special pretty much just some clutches i was wondering about how much power it should be able to hold up to
Old 12-11-2012, 06:10 PM
murphinator's Avatar
about 20 years ago I had a small block nova that ran 12.5's for me on a $50 junkyard turbo 350 with just a shift kit and convertor , unknown miles. the lighter the car is generally the lower in et a certain trans can take
Old 12-11-2012, 06:51 PM
ya i hope it hold up i think it has about 400 rwhp right now but its in a foxbody mustang thats pretty much gutted so its pretty light
Old 12-11-2012, 08:45 PM
carlsonauto's Avatar
In a light car that doesnt make gobs of power it will hold up pretty well. With an all stock unmodified TH350 I would be willing to bet that rpm is what is going to kill it depending what rpm you turn. With a stock direct clutch it will centrifugally apply at high rpm, the cast sealing rings will chew the pump up and the pump itself if not set up properly wont have the longest life either. If you are shifting at 5k rpm you are good, If you are twisting it to 8k rpm its not long for this world..
Old 12-13-2012, 01:13 PM
im shifting right about in the middle at 6700
Old 12-13-2012, 02:06 PM
If it was mine I would at least pull the pump and direct clutch out. Drill a bleed hole in the direct clutch drum and put teflon rings on the pump. It might be fine without but I doubt it thats kind of pushing it..
Old 12-14-2012, 01:37 PM
Camaro396's Avatar
I was in the same boat as you. After my cam swap and 90k miles my stock 4l60e had given up. I had a "600hp" rated th350 (TCI manual valve body, good clutches, reverse pattern shift, ect) laying around from another car I had, and I swapped it into my 2000 Z28 that made 447rwhp and blew it up in less than 100 miles. Had it rebuilt locally, put it in, it lasted about another 75-100 miles and I broke the 2nd gear sprag. Sold the car, new owner bought some 700hp rated TH350 to put in it and has had good luck ever since from what I hear. For me, I wish I would've just went TH400 from the start, but I didn't want to change crossmembers and driveshafts AGAIN after just completing the th350 swap.
Old 12-14-2012, 01:42 PM
SnIpEz's Avatar
The bleed hole should be about 0.060". If you do tear it open, I'd also make sure you dual feed those direct clutches, it will require either a cup plug or tapping and putting in a set screw in the case.
Old 12-15-2012, 01:03 PM
does it really help alot to get a manual valve body everyone keps telling me to do it but if i shift it manually when i race what is the big deal ?
Old 12-15-2012, 02:32 PM
Camaro396's Avatar
A lot of people use manual valve bodies so they don't have to worry about finding vacuum to shift the trans. Plus manual valve bodies are much funner!!
Old 12-15-2012, 04:55 PM
does it make difference if ir is a reverse maunal valve body or not ?
Quick Reply: turbo 350
