Check Gauges Light On???
Well when I was driving home today my check gauges light came on and I was running low on fuel, so I stopped at the gas station and pumped some fuel. After I finished pumping fuel I drove off and the check gauges light lit up again, checked all the gauges everything seems to be fine and now the light wont turn off? Any ideas?
Thanks
Thanks
Go to autozone and have them check and clear the code. Some codes takes a few cycles of operation to clear... Depending on the reason for the code.
They can tell you what the code means... Or at least give the # so you can search on line. Clear it and if it comes back then maybe you need to do something.
