408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29
Old 12-13-2012, 12:05 AM
BlackWS666's Avatar
Default 408, GT55-94, E85, Glide, Truck manifold build & result -- 7/10/14 --8.87 @ 158 VID
Build thread number 2. Here is the link to the previous build : https://ls1tech.com/forums/forced-in...e-12-10-a.html
After ending the season to a lean number 7 cylinder i decided to make some serious changes to the setup, and after much debate.... share them with my fellow tech followers. I cant complain about how the first setup worked, but now that i have a lot of bugs and tests worked out of the car she is ready for round 2. Here is a shakedown of the basic setup and changes:
Iron 6.0 block
Eagle 4.00" crank
Compstar 6.125" rods
Wiseco -3 dish pistons/Wiseco rings
LS9 heads
Cometic head gaskets
Brian Tooley springs
Comp Cam(Martin@Tick Performance)
1/2"ARP studs
Holley Hi-ram
102TB
160lb high imp injectors from FIC
Pump E85
Magnafuel 750 prostar pump
Nasty nate cell
Tuned by Myself
Garrett GT55-94 turbo
1.40 exhaust housing
truck manifolds w/ v-bands
2 x JGS 40mm wastegates
JGS 60mm BOV
5" Downpipe
2.25" crossovers
Powerglide Transmission
Dedenbear case
1.80 straight cut gearset
Burkhart Fabricated 9"
3.50 gear
35 spline moser axles
Lightweight spool and center section
Aluminum 3.5" driveshaft
Car is WAY under the knife at the moment, getting it ready to head to Burkhart Chassis for a moly 10 point. Currently ive relocated the fuse boxes under the dash next to the PCM. That was a real son of a *****!! About to paint under the engine bay which should be equally fun. I will do my best to keep the thread updated.
What ended my season
Time to upgrade Yoke
Relocation fuse boxes
Attached Thumbnails 408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29-010-1.jpg   408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29-033-1.jpg   408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29-138-1.jpg
Old 12-13-2012, 06:06 AM
turbocamaro125's Avatar
Should be faster now
Old 12-13-2012, 07:41 AM
I8UR4RD's Avatar
yours is my fav car on tech. I look forward to seeing your progress.
Old 12-13-2012, 07:50 AM
AutomagicLS1's Avatar
that car should make retarded power. I hope u are finally able to turn't it up
Old 12-13-2012, 08:14 AM
Destroyer of Exotics
FlashWS6's Avatar
Badass! Looks like there's gonna be 2 cars on tech using that Turbo
Old 12-13-2012, 09:22 AM
28-30psi wasnt turned up?
Old 12-13-2012, 10:18 AM
Sales@Tick's Avatar
Can't wait Kyle!!!!
Old 12-13-2012, 12:14 PM
BlackWS666's Avatar
Thanks guys. yea she was turned up alright. Just never could get a real clean pass. But the trap speeds reassured me the power was there. Just some slight tweaks with compression, a few more cubes, better heads, and a cam speced out to me. I havent forgotten about you martin!!! Im trying to get the cage first.
Old 12-13-2012, 12:22 PM
Sales@Tick's Avatar
Oh I see, I'm the last thing on the list.....
Old 12-13-2012, 03:59 PM
RacerXLs1's Avatar
Can't wait to see this new setup!! 100k meltdown?
Old 12-13-2012, 07:15 PM
BlackWS666's Avatar
Man i would love to!!!! But with what im hearing unless your **** goes 7s then dont bother. haha. I will be there to watch though no doubt!!
Here are some pics of the LS9 heads. I know there stock heads, but they are supposed to be king dingaling of all that is stock heads. Plus i really really wanted to experiment with a better flow rectangular port head.
Attached Thumbnails 408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29-008-1.jpg   408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29-009-1.jpg   408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29-012-1.jpg
Old 12-13-2012, 07:26 PM
dudeman's Avatar
should haul the mail. what did it run on the old setup?
Old 12-13-2012, 08:01 PM
BlackWS666's Avatar
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
went 9.0 @ 158
Old 12-13-2012, 08:26 PM
dudeman's Avatar
thats moving out for sure. what did that thing weigh in at?
Old 12-13-2012, 08:30 PM
jridenour31's Avatar
Has anybody cut a set of these heads apart and measured deck thickness or know what it is? How much were they?
Old 12-13-2012, 09:31 PM
BlackWS666's Avatar
weighed 3050 on the scales. 3225 raceweight.
I got them from a member on another page. got them for a good deal because they are slightly used (500 miles). Can get them new from GM for around 1000 a piece fully assembled. I wasnt to worried about the thickness as my 317s held fine with almost 30psi on LS9 gaskets and the 1/2 studs. And these LS9s are thicker, and made of a better material.
Old 12-13-2012, 09:39 PM
dudeman's Avatar
weighed 2050 on the scales. 2225 raceweight.
2225? or 3225?
Old 12-13-2012, 09:51 PM
Yeah, I didn't really think it would be an issue, was just curious if they were considerably beefier.
Old 12-13-2012, 10:01 PM
BlackWS666's Avatar
correction 3225.
Old 12-14-2012, 09:07 AM
mehoffz24's Avatar
I can't wait to see some more pics
Quick Reply: 408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29
