28.8 injectors top out @ xxxxxx
Old 12-13-2012, 11:25 AM
A.R. Shale Targa's Avatar
Default 28.8 injectors top out @ xxxxxx
How much power have people made on the stock 03 injectors before
needing to upgrade to 36 or 42 lb. ers ?????
Seems I've heard in the 400-430 range but SAE vs STD can skew that a bit.
Just trying to plan for a potential upgrade......
Old 12-13-2012, 11:27 AM
Tainted's Avatar
400rwhp is a good time you should be looking to upgrade. in general you dont want to run your injectors past 80% duty
Old 12-13-2012, 11:36 AM
Super Hulk Smash
JakeFusion's Avatar
Yeah, for piece of mind I'd look at some FIC 42lbs once you got up over 420rwhp. They are 239 and are flow matched.
Old 12-13-2012, 11:45 AM
thunderstruck507's Avatar
I was hitting in the 90% range with 230/224 cam, headers, FAST 90mm. Computer estimates based on track times put that at ~370rwhp through the auto/12 bolt.
Once I went 230/238 cam with mildly worked 799s (estimated 400-410rwhp through the auto), I was over 100% DC by ~5000rpm. I got GM supercharged 3800 injectors on ebay for around $100. They are 41.5# at ls1 fuel psi.
Old 12-13-2012, 11:47 AM
Since I plan to max at about 420ish would a Ford red top or LS2 36 lb be more
in line with my power level...considering 42s are good to what 500ish ???/
Old 12-13-2012, 11:50 AM
Good to know.....are they the same dimensions (height wise) and does the
harness need adapters or anything ????
Old 12-13-2012, 11:52 AM
Plug and play. I switched them out then adjusted the flow rate table in the tune and then did a touch up tune on the VE and MAF. Been that way for a year now.
They look just like ls1 injectors except they are white. I was told GM does sell other white ones so look up the part number and buy based on that, not color.
Old 12-13-2012, 10:35 PM
Thanks for responses......
Quick Reply: 28.8 injectors top out @ xxxxxx
